The boost drops off a fair bit up top.
303kw on about 22psi droping back to 19/18psi is a decent result, but it doesnt seem that much different to the g2.5 in terms of response.
The g2.5 made close to that power running 98 on only 20psi didnt it? and pretty close to 200kw at 4000rpm as well
Edited by Mitcho_7
Yeah it's looking like the turbo I'll be after. Want to hit 300rwkw or near enough and hopefully shoot above with e85 if it's ever readily available where I live.
Was gonna use stock manifold but after looking what Stao has said and the Dyno graphs I think I will look at getting a 6boost or brea manifold, depending what is available to me
The temptation to go external gate is there, but I think I'll stand by internal gate
same turbo just pump 98 internally gated. Only shows bit more responsive on paper, but on road its very different to the G2.5. Further response gain will cost top end power unless going external gate.
How ever small differences do adds making a pretty big difference looking back to the old G3. So just have to keep on working at it.
Results from the newer SS2 prototype on Pump 98 internally gated in bolt form. It made final of 302rwkws and did actually manage 200rwkws by 4000RPMs. Pretty sweet to drive on road. At this stage that every HP its getting is based on a trade off of some response. Probably only a tinny bit more room to play with. I will trail one more wheel on it in about a week time.
Wow I'm excited. Glad I sent it back for updates.
What is the difference between this and the other wheel you will be testing next?
Different profiled wheel blades, also complete with a bigger turbine housing.
I've made one more billet wheel with minor alterations to the hub that I like to get some result off.
Just over-layed new Ss2 against old ex gate 307 result and original 315 int gate result on paper.
New one is impressive. New vs 307 are identical from 4500 to redline. 307 makes more around 3700 but dips at 4100 then they meet up.
Original 315 makes less from 33-5500 of up to 60hp then only makes a bit more to redline compared.
Excellent result
Stao,
Any hope in a twin scroll internally gated turbo making somewhere over 300rwkWs on 98 & full noise around 3500 to 3700 rpm?
Here's an example of what the EVO boys use:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-VEVO-039&Category_Code=NEW
The idea of running twin external gates etc.. too much money & space used up.
Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Edited by t_revz
Stao,
http://www.atpturbo....tegory_Code=NEW
If that turbo was on decent boost before 5500rpm I would be supprised
Edited by SimonR32
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
