T revs ah OK. Well I have that one. Lol.
I will be running 98 due to the fact I do a lot of mountain runs and track days and e85 is not available as much as I would need. But saying that I have 044 in tank and 740cc deatzwork injectors. So I have room to play for e85 when I get used to the power of 98. Its like a free upgrade and by then there will be more servos
Haha. Dual gate is true. But the internal one is locked of with a pin and is nice and sealed. I did it so I have better resale value as well as the option to use it for EPA excuses/rectification and the most important reason for me, bolts to existing dump pipe. Nice and easy
lol Dan, yours makes mine look like a brand new clutch. Speaking of which, reco gearbox and new clutch are in. It was dragging at first, so I swapped in a longer slave pushrod and adjusted the pedal. Now the take up point is a little too high, so I have to adjust the pedal again -_-
Only been on a short test drive, but she feels great so far - no more crunchy gears and the organic clutch is very friendly. Can't wait for my 1000km run-in period to finish, then I can see how this NPC holds up to the SS1PU...AND GET AN E-FLEX TUNE!
no more crunchy gears :woot:, sounds like somethings wrong with it man pretty sure its meant to crunch :P
whats a gearbox reco usually worth..
Stao what would be the going rate for GT2871R or equivalent cores into stock 300ZX housings? Saw another 300ZX running this and getting good results so just asking.
Yeah the poor thing took a beating!
So I found the rattling noise in my clutch goes away when I slightly touch my foot on the pedal this is before the pressure point.
Should have it back out in the next week and then we will know what's going on.
Can't wait to see your 85 tune and what power it makes! As soon as tax comes im hitting it up and also going to get stao to swap me a 14psi actuator
Your rattling is the thrust bearing, 99.9%. It's common with aftermarket bearings...spraying grease on the thrust carrier/bearing through the clutch fork cover can help.
From memory Race Pace put a weaker spring in my actuator to dial back the preload.
Well for me it's free (:P), but it starts at $1500 and finishes at $2100 for a worst case scenario box.
They are 1600 for the pair. Equivalent to 52t.
how are people killing these excedy cushion buttons with 200/250rwkw i got the hhhhdcb7056 has handled a 330rwkw rb30det now in a rb25det still going strong
Cushion button isn't that heavy duty; the clamping load load is what lets go under power. It's just a very good clutch for launching hard and retaining daily driving ability in a standard or slightly modified vehicle.
That's coz its a HHH lol... The others are only running single heavy Duty stuff
This
But I still think mine should have handled 195rwkw for more then 8 months or whatever it was
Can't thrash it yet, but I'm already noticing the difference in drivability. Strangely, my KAAZ behaves better through low speed turns or when slipping the clutch - bonus! And even though it's organic, this clutch has more on/off action than the cushion button (go figure?), you have to have a decent amount of revs to take off smoothly or be precise with the take up point - love it! It's also possible I now have a lighter flywheel because of all the meat they had to take off it lol.
picka-boo TiAL :D ... pretty happy with the end result.
only on 10psi at the moment but holds dead flat, car is alot faster and spins all off second if i dump the clutch which it wouldn't do before.
Booking a tune at Chequered Tuning next week, aiming for 280rwkw at 18-19psi
Yes that is.
I'm recently putting in lots of thoughts into modifying stock exhaust manifold. All we had to do on it is basically mill out the top layer of the cast, weld in larger diameter of steam pipe and external gate port. Should be producing same results as any of the $1000+ exhaust manifolds, while probably cost a third of it.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
