Turbo feels like it will make heaps of power and feels pretty responsive considering I doubled the a/r on the exhuast housing. Might boost it to 12psi to see if theres a big change. I just can't believe how well the tial controls the boost. Nothing comes out The screamer until like 9-9.5 psi.
Did a naughty today and gave my car some full boost in a couple of gears to test the new clutch; I'm supposed to be running in a gearbox...
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me there so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Now to be good for the rest of my gearbox run in period :/
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me to 100 so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Lol..yeah i was amazed how fast my car actually was with a decent clutch installed too.... anything over 4000rpm just gets scary now :laugh:
Can't wait to see the tune results
Stao, have you ever thought about doing a twin scroll turbine housing or are they too expensive to produce?
The turbo is not expansive to produce. all I have to do is slot the .82 rear housing in the center and insert an divider then profile the housing to suit turbine wheel, and we have a real twin scroll turbine housing. How ever it must be used on a twin scroll manifold as well external gate (preferably 2).
any chance of a internally gated twin scroll? I'll be down for that!
Didn't KKR produced a twins scroll internally gated turbine housing for their KKR480 and 560 turbos years back? It ring a bell as I have read many complaints about their lack in ability of boost control.
Wouldn't surprise me if they struggled with boost control. There is probably a reason you don't see many, if any twin scroll internally gated turbine housings
Edited by Mitcho_7
EVOs, STIs run internally gated twin scrolls. I just want it for simplicity & the "kinda" stock look instead of 2x gates hanging off the manifold.
Yeh, itd definently be worth a try i think, providing you can get it to control boost well. Sure as hell beats having to fiddle with plumbing up two external gates in that limited space.
Edited by Mitcho_7
One external gate is fine if you run the splitter right up to the gate valve.
I just don't think there is room to effectively flow the gasses on internally gated housings, other than the BW, they nailed it, but it makes the rear housing too large.
picka-boo TiAL :D ... pretty happy with the end result.
only on 10psi at the moment but holds dead flat, car is alot faster and spins all off second if i dump the clutch which it wouldn't do before.
Booking a tune at Chequered Tuning next week, aiming for 280rwkw at 18-19psi
do you have photos of the manifold? I'm curious :)
Just Google rb25 manifold lol. I haven't done anything to manifold. The external gate is off the rear housing. It was cheaper, easier, and I could use my factory crossover pipe with no mods. Just have to chop up the heat shield a bit.
LOL
got photos of the rear housing?
derrrr a few pages back lol nvm... I notice the internal gate is still there??
Edited by johnnilicte
Haha. Dual gate is true. But the internal one is locked of with a pin and is nice and sealed. I did it so I have better resale value as well as the option to use it for EPA excuses/rectification and the most important reason for me, bolts to existing dump pipe. Nice and easy
Just got to read from the photos onwards
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
