Turbo feels like it will make heaps of power and feels pretty responsive considering I doubled the a/r on the exhuast housing. Might boost it to 12psi to see if theres a big change. I just can't believe how well the tial controls the boost. Nothing comes out The screamer until like 9-9.5 psi.
Did a naughty today and gave my car some full boost in a couple of gears to test the new clutch; I'm supposed to be running in a gearbox...
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me there so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Now to be good for the rest of my gearbox run in period :/
Fark me, not sure if I'll need E-flex straight away. On the freeway ramp 2nd took me to 100 so fast I couldn't even enjoy it lol. And third gear roll from 80km/h is ridiculously good fun. <3 SS1PU
Lol..yeah i was amazed how fast my car actually was with a decent clutch installed too.... anything over 4000rpm just gets scary now :laugh:
Can't wait to see the tune results
Stao, have you ever thought about doing a twin scroll turbine housing or are they too expensive to produce?
The turbo is not expansive to produce. all I have to do is slot the .82 rear housing in the center and insert an divider then profile the housing to suit turbine wheel, and we have a real twin scroll turbine housing. How ever it must be used on a twin scroll manifold as well external gate (preferably 2).
any chance of a internally gated twin scroll? I'll be down for that!
Didn't KKR produced a twins scroll internally gated turbine housing for their KKR480 and 560 turbos years back? It ring a bell as I have read many complaints about their lack in ability of boost control.
Wouldn't surprise me if they struggled with boost control. There is probably a reason you don't see many, if any twin scroll internally gated turbine housings
Edited by Mitcho_7
EVOs, STIs run internally gated twin scrolls. I just want it for simplicity & the "kinda" stock look instead of 2x gates hanging off the manifold.
Yeh, itd definently be worth a try i think, providing you can get it to control boost well. Sure as hell beats having to fiddle with plumbing up two external gates in that limited space.
Edited by Mitcho_7
One external gate is fine if you run the splitter right up to the gate valve.
I just don't think there is room to effectively flow the gasses on internally gated housings, other than the BW, they nailed it, but it makes the rear housing too large.
picka-boo TiAL :D ... pretty happy with the end result.
only on 10psi at the moment but holds dead flat, car is alot faster and spins all off second if i dump the clutch which it wouldn't do before.
Booking a tune at Chequered Tuning next week, aiming for 280rwkw at 18-19psi
do you have photos of the manifold? I'm curious :)
Just Google rb25 manifold lol. I haven't done anything to manifold. The external gate is off the rear housing. It was cheaper, easier, and I could use my factory crossover pipe with no mods. Just have to chop up the heat shield a bit.
LOL
got photos of the rear housing?
derrrr a few pages back lol nvm... I notice the internal gate is still there??
Edited by johnnilicte
Haha. Dual gate is true. But the internal one is locked of with a pin and is nice and sealed. I did it so I have better resale value as well as the option to use it for EPA excuses/rectification and the most important reason for me, bolts to existing dump pipe. Nice and easy
Just got to read from the photos onwards
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
    • Yep four point harness. Mounted to a bolted in brace running behind the seats. Dont use it for daily driving tbh but good to have for when its needed plus it looks cool.
    • I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
