50cm?? Thats half a meter before.. Is there even half a meter of pipe from cooler to TB?
I'm sitting inside and haven't looked at it for a while, my judgement of distance is definitely off haha.
It's near enough to where the pipe comes through my cold air box.
You want it to be as close to the compressor housing of the turbo as possible. If your running actuator pressure you can also pop a nipple on the comp housing and run it straight from there to there.
Why is this, exactly? The only reason I can think of is to avoid overworking the turbo if your cooler is a restriction, but at such a measly boost level that I'm running I can hardly see that being of concern.
Actuator reaction.
If the surge is created by a minor overboost at those revs/throttle then moving the reference nipple will mean the actuator reacts quicker and can overcome the problem.
Thats assuming the surge is created by that specific issue.
Okay so the reply back from JJR is that all there dumps/front pipes are the same so mine was not a defective product.
No no What they are saying is, All my dump pipes are defective. You like you buy.
Edited by GeorgesR34
I might look into having that done then - would the turbo need to be removed to put a nipple on the outlet though? I would think this would only be for safety reasons to avoid metal shavings falling down to the compressor.
To make it simpler just get one welded on the cooler pipe as close to the turbo as possible.
Should work to the same effect mate.
Stao is it possibly you can produce these with a nipple on the cover from now on?
I was a little :( when I didnt find a reference nipple on mine but there were 2 casting marks indicating where it could be fitted.
^^this. I welded an 1/8 npt socket onto the underside of the pipe out of view then screwed a barb fitting in
cbf, lol. But yeah if (when) I next remove the turbo I'll have one put on the comp cover for sure.
Yes I have stock of the billet 20G but only in a 10cm T3 rear. I can sale you the core for $700 if you want, which you can run that in your current 8cm housing.
18G, and 25G plus 8cm turbine housings are still work in progress at this stage.
Ok , so what are the advantages of billet wheels compared to the ones on the one i have now? (just talking myself into it really, just seeing if i can justify the extra $$) the car that the turbo will be going on will be used mainly for track work so it will get a hefty work out!
Well if the comp wheel is made exactly the same to original caste then it makes no differences. lol
For our billet wheels we run a different sized hub with slightly taller inducer and blade curvature. All manufactures has their own wheel profiles, so there won't be an identical billet turbo result.
The currently 20G follows our SS hub and blade profile, that is engineered to produce the most Power with Least RPMs. So the car comes alive as soon as its on gas. You can see that worked extremely well refer to test result based on a SR20det None Vct motor, and no one has yet managed to get 200rwkws by 4000Rpms on same setup. Its going to be crazy responsive working with the Rb25det. I would expect the end result be similar to the SS1PU with more top end since working with proper manifold and external gate.
I reckon i might get a 8cm housing and one of these Billet 20G's and jam it on the 4AGZE Ke10 rolla i have here with some E85 in the mix..be epic on 30psi..lol
have a killer ex manifold here for one, be a shame to waste it..lol
cheers
darren
Edited by jet_r31
This is a pretty good result from a high flowed Rb20det turbocharger bolted on to a stock rb20det motor internally gated. Green is 98 and red id E85 limited by fuel pump. Hopping to see around 250rwkws with fuel pump replaced.
cheers
darren
For 4AGZE Ke10 rolla, Here's a result from a ATR28G2. Good chance cracking 300rwkws on 24psi on e85 :yes:
Just to ammend ur last post Tao, the red and green are e85 but hi and low boost. I will get an overlay of the 98 runs from before i converted it to ethanol
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
