Thanks Roy! That looks quite nasty.....:(
Will definately do something about this manifold. Maybe I need to make a custom heat shield
Stock one had a heat shield where this does not
Edited by blah_blah
ACL heatshield is awsome stuff, you can bend and cut it into any shape you need :) i also heat wrapped the manifold and part of the dump, used heat shield sleeving on the oil and water lines, aswell as a turbo beanie.
After doing a bit of reading this morning. The ACL Heatshields seem to be the go :thumbsup:
http://www.aclperformance.com.au/prod_heatshield.htm
Yeh ACL is good stuff, but with that sort of dump and manifold setup I think you will have trouble making a decent arrangement. Under the sheathing over the coolant hoses going into the firewall std Nissan hoses that have been wrapped in DEI no leaks to further make the new hose robust.
When you are driving arount at wide open throttle for 15 minutes with everything glowing red everything goes to shit. Even loom clips nowehere near the immediate heat sources harden and become nice and crispy. If its less circuit car and just a club car doing track work then the concern over heat control is a little less
Bringing a 6" flexible duct up from the front of the car to dump cooling air in the region can help too. Even if it doesn't noticeably cool the hot stuff, it will take some heat away from the stuff that's not meant to be hot.
Just a daily car doing club track work via SAU VIC and other car clubs.
Winton isn't too much a problem.
But somewhere like Sandown and Phillip Island (Havent been but assuming so) might be
With the stock setup, car was getting really hot under the car and oil temps up to 130 towards the end of the day at Sandown. So would only last about 8-10 mins out of a 15min session before oil temps started to get out of control. This was on a 20c day.
So now with this new manifold, turbo and summer approaching. Hoping heat shielding and an oil cooler will do the trick.
Seems a bit of a waste doing track days and having to pull in early in sessions because your car is overheating
Yeh, maybe...but I don't like that idea on my car. Too much heat-temp cycling. If you run a bit duct so its all low velocity and you dont get cold spots...but not very practical given how busy it all it in there. I also ran my inlet temp thermocouple around the strut tower whilst I was doing my shielding etc years ago and i think the main thing is keep the heat in the hot things and try to have slow heating and cooling....with it protect the things that dont like heat and then typically saloon cars with copious amount of 60deg air coming through the radiator gives enough airflow through the engine bay...for me a better approach since i dont want any ducting etc in my bonnet. But others may be able to make it work
Did some jigging today. I can make TD06SL2 20G / 18G or TD05H 18G into a bolton turbocharger for Nissan Rb engines, how ever only in a 8cm housing at current stage. It will cost $300 additional. Since most internally gated TDxx results are rather disappointing, the ATR series are still better choices of a bolton turbocharger, how ever send in PM if any one wish to get one made and have a go at.
The curvature of the blade is too far curved, specially in a 8cm its going to chock the engine badly, and putting on heaps of load onto the thrust collar. Its good for small engines. Under comparison, the SL2 turbine appears much better for a Rb20/25 motor.
The TD05H seems to pump a fair amount of volume on a 4G63, up to 300kw on E85 from memory (with custom spec compressors).
Trent has also said 280kw from one is not hard to achieve. (TD05H 18g 10cm).
That being said. 280kw from an SR or 280kw from an RB is the same amount of exhaust gas flow regardless. Power = flow. Right?
You have the thing able to be put on, just trial it on your own car and see.
Nope, bigger engines actually result in much high back pressure and lot more heat when constrained by a small turbine, its different when fitted on to a smaller engine. So this turbo might reach 250rwkws on a worked SR20det, but won't be able to reach that on a RB25det, probably going to pin its head off on boost.
This is the new 3inch Vband dump adaptor with a large 38mm internal gate that I've been working on earlier and it is now complete.
The 3.5 inches front pipe that I would like to offer with this turbine housing has been made (by Drifthovic SAU: Abe2 <= this guy also makes stainless stell 3inch lobster induction pipes for high flow and other turbos)
After looking into my Xforce front pipe. it appears it was a straight pipe bent into shape by a bender, not mandrel bents. The area that it bents were only 2.5 inches.
With the new front pipe installed, the exhaust sounded alittle louder. and felt torquier in the mid-upper rev range.
Price for the cnc internal gate assembly is $350
3inch mandrel bend front pipe to cat is: $220
3.5 inches lobster bend (show on photo) is $270.
So for example a ATR43G3 with above assembly and 3inch mandrel bend front pipe would be:
$900 (turbo) + 350 (cnc internal gate assembly) + 220 (front pipe) = $1470
The CNC internal gate assembly and front pipe also fits any ATR43's .82 turbine housings.
This setup will allow the turbocharger to perform much betterly compare to some of the CN imported front pipes.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
