Is that an aluminium elbow welded on there? 2.5"?
Yep ebay china spec..same as comp cover lol, ive been playing a game with this car,, try keep it cheap as possible, but also make shit last since its a roadtrip /family
car, that spend all its time in the hills, i didn't feel like replacing a 90 degree piece of silicon due heat every 2 ish yrs, hence the alloy 90, and its moves it fair away from standard,and higher aswell, just all fitted still with longer silicon joiner and a twist of stock intercooler pipe.
Braided cloth oil return, aluminium elbow, steel factory water lines, some ACL GTR heatshield on things, i am hoping i don't have to do no maintenance besides changing oil ever 5000km
cheers
darren
Edited by jet_r31
lol go the giant external gate daz
haha...its was free..i had a old school 45mm turbodumb aswell sitting around .it did not fit as it was to tall, if i bought one i would definitly get a tial 38,
more flow and valve lift in same package. I hate internal gates.
90 percent the of the stuff i got is s/h or sitting around my shed , except for turbo and scotty intake (which fitted well, even though i changed the cooler pipe route, it still has 10mm clearance .Same as bloody silicon..i wanted black, but i found a big piece of blue
in the shed..so i am using that. I am not scared of boost , if it makes power at 23-24psi, its coping it,
Staos auto record better get smashed..lol
i upgraded the wmi to a 600cc jet and may put it pre-turbo for testing , hopefullly the fat pig runs some 12's, i wanna see results, can't wait to smash it on the wastegate..lol
cheers
darren
Edited by jet_r31
yep, i lol'd, i bought it as its the only turbo Stao didn't change as much as his underpants..then i fitted it and he changed it...hahahahaha
Oh well, it will be better than what was on there, when i pulled it apart, the turbo bolts where loose , the exhaust mani bolts where loose
and the turbo side intercooler piping was not done up..it was laggy a f**k and whistled like a kettle for last 12 months, i just
cbf'd tracking it till i did turbo change ...bloody japanese muckanics..lol
cheers
I bought one of those hypergear modified Td06 20G billets for my 4age turbo aswell Scott, got a 8cm housing for it
cheers
darren
Edited by jet_r31
LOL! how does it freaking get that bad..
admittedly tho, i got a cooler put on my car once and got it back from the mechanic with the two rear turbo bolts undone. the tabs had been pushes back and you could see the marks of double hex sockets being used on a long crooked extension.
never want to have work done by a mechanic ever again, unless i absolutely have to.
if mechanics can f**k things up then why cant i? :P
lol generally i can do anything necessary.. yet that particular job was a FMIC on an NXR, which had to be custom. So they were employed to make up the pipes etc.
Turns out they wanted some return business.
ive done countless motor swaps and conversions myself, including a full build on my current SR. that was truly a one off. I may even learn to make my own pipes, screw having someone try to bend me over like that again. FYI I fixed that myself too lol kents
Just get an NPC organic, will handle 300kWs easily. Just talk to a fella name Doug from NPC, he's pretty cool!
I decided to be stupid and get the carbotic version, going up shopping centre carparks usually result in hops or chirps LOL
NPC 10" sprung button in my car for near 3 years now I think. Been handling 255rwkw easily. Never had any issues and couldn't be happier. If you have the money go the lightweight flywheel off NPC as well
I've heard good things about NPC before, but don't really know much about specifics of their products.
You got Doug's contact details Johnny? :)
Here you go :)
[email protected]
07 3277 9403
Ask for Doug, I'm sure he has dealt with many Skyline fellas in the past. He said the organic will easily handle 300 kWs, and the carbotic up to 400kWs.
He didn't disclose too much information, but from what I can tell the pressure plate is either from a 300ZX or a Patrol which they apply some magic too. This increases clamp but doesn't affect pedal feel, to be honest my pedal feels as soft (if not softer) than a standard Exedy OEM Replacement clutch. Also from my experience, the NPC 10" Carbotic is a tad more forgiving than a Exedy (NC10T) Sports Ceramic (4x puk from GT-R on a GTS-t). I can take off from slopes without looking like a moron LOL
So no need to waste money on NISMO pivot and NISMO slave
P.S. I don't work for NPC, but buy from them directly cheaper than resellers
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
