thats a crazy result.. I like the way the torque stacks and fades off. I'd probably want that exact result for myself if I had an R33.
Is the CHRA in that SS2 core any different to the normal SS2?
22psi on e85 and shinnnnnnnnnning Dou dou dou dou
I will upload all the papers when I get a computer tonight. Doing it with my phone and it sucks.
Here is the dyno reading:
Boost:
Super responsive. Makes That about the same response as the SS1PU. Makes 17psi by 3500RPMs and about 100kws by 3000.
I will upload the videos shortly.
Video footage from today.
Surprisingly after multiple runs, the turbine housing or manifold did not turn red or overly heated. I guess this is the highest no. that a highflowed r33 turbocharger in factory housings has ever archived. This evaluation is pretty successful.
It how ever do cost $200 more then factory high flow option, for the extra work required on modifying standard turbine housing, as well as the high pressure actuator and SS2 billet compressor wheel.
I believe it is good for some where around the 280rwkws when used on stock manifold, internally gated on pump 98 fuel with good supporting mods and tune.
Yes the ATR43SS1 result of it on a Rb20det is on our site. SS1 billet version is updated version with better response. How ever I don't have a result of it based on a Rb25det.
Op6 should net around 370rwkws mark in this combination. I think I can get it close to 400rwkws with a different set of compressor profile. How ever it will be much laggier.
By the way, the SS2.5 is a CHRA made only for RB high flows, specially the 21U R33 housings. Won't be great used in normal housings.
I can also build the SS2.5 using the latest G3 comp wheel. Which will not add any costs to the standard profile while producing identical amount of power.
Standard high flow can get you a very responsive 250rwkws, while the SS2.5 or G3.5 can make more power will be laggy in the op6 rear housing.
I can do a special deal on the evaluation price of the G3.5. PM for further details.
Stao, that highflow is redonkulous.
What would that in an OP6 housing cost?
Every time I settle on a plan you go and do something that throws a spanner in the works....
I will do a special deal at $1160 including oil line. it might not be as responsive in the OP6 rear, how ever that should be reaching close to 370rwkws mark once setup on a proper manifold and gate.
Also releasing one more profile for the 21U turbine housing is the G3.5 This turbocharger is also a specific high flow built chra. it should produce bit more then the SS2.5. Hopefully be seeing towards 350rwkws mark. Its been pretty responsive using the 21U turbine housing.
Few other news is that I've managed to source some R33 copy turbine housings. That will help saving lot of costs building them here. I will pass on the savings and work out a cheaper alternative to high flows very soon.
  • Like 1
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
