In that case I'd just look at optimising the existing g3. I have the "old" one and I think it's great. And I don't think even have it high mounted and gated etc. Once the motor's breathing in and out properly you won't recognise it. :)
That is very responsive for a SR20det. Not your car?
Also latest video from SSRicho. 1.31 lap time run at winton raceway.
R33 skyline. running our 21U high flow on 263rwkws.
This is the SAU VIC lap record at Winton.
From a turbo I've had for 3 years and done well over 30 track days.
The response from this turbo and the way it's tuned are perfect for Winton. I change gears 4 times (2x up, 2x down). 3rd gear pulls from 65kmh all the way to 160kmh.
After I give it a full cat back exhaust the boost level jumped 1.5psi. Did many launches measuring 0~100KM/H time. Its now sitting on about 7.5 secs from 14.5 factory (<= can you imagine what 0~100KM/H in 14.5 sec is like?).
hey stao how much is that top mount brae manfiold you use worth?
That one was $1100. I have a side mount manifold that you can have at same cost which holds the turbocharger on stock position. That has external gate port with plug made in case of running internal.
Lol was your Chinese counterpart happy with the sportage kit? Going to order many?
Hopefully so. they are still setting up a Testing rig there. If quantity is big I will move over there and build turbos for your guys at half price.
Lol! Shipping from China? im guessing half your production cost is shipping low volume material to aus before you can make your product and sell to us.
That is true, I've mentioned it before, some the housing castings Came in from overseas. they are quality castings, been through time and well tested. Join in part of globalization running through any other firms. Other wise it is not possible to produce at a cost that the majority can afford to pay today.
All machinery work turn casting into some thing useful as well as CHRA work are precisely done in Australia. That takes the majority of the cost in building the actual turbocharger. I've been pushing up in volume to drop costs so our products are more affordable, how ever I can not get rid of the cost of factory on goings as well as keeping good engineers.
About Chinese workmanship, we are seeing poor quality / low performance turbochargers because the people whom manufacturing them does not know the actual purpose of their products, instead paying more attention into what makes them $2 by such time it sales. They are businessman, not engineers, certainly not a automotive enthusiastic or have any knowledge in modifying a Skyline.
If I do fully establish in China, I can hire quality engineers at $5/H and train them to precisely build what I wanted, with much less running costs. Pass on all of that into consumers that takes away close to half of the retail costs. But its only worth considering if I have a permanent place in Chinese domestic market.
count me in too! hahahaha (I'm so over desk jobs, farking blows.. I go to work and want to punch everyone)
I've got some road experience in tuning (only with my car and a few of my friends)
Ok, so I got round to doing another leak test on my car using compressed air, first time I have done it since the last mods. I found three very big ones; one was a split in the silicon joiner on my turbo/intake caused by the hose clamp, one was the hose going to my fuel pressure regulator, and one was some very shit welding of the IAT sensor done by a certain workshop here which shall remain unnamed. These are all now fixed.
Before I found these three, I couldn't even pump 2psi into the thing, it was bleeding off air too quickly. It now takes 10+psi, which is apparently the limit of the plug I made for the intake pipe, the end cap explodes out of the rubber joiner with quite a bang :laugh:. I might see if I can fix this somehow, either a better clamp or just epoxy the end cap to the joiner, try to get the system to hold 25+psi. Anyway, the intake now holds pressure quite solidly, and given the rate of how quickly it would bleed off pressure before, I have no doubt this would have affected the performance.
I will still degree the camshafts this week to cross that off the list as well, then I guess it's back on the dyno to see if there are any changes!
Edited by Hanaldo
Haha, thanks mate :)
I am also going to borrow or purchase some tungsten carbide rotary burrs. Need to pull off my JJR bellmouth dump pipe and match the opening to the gasket. Might also port the stock manifold while I'm there.
Further up dates. Most of our work up to date are around the 500HP range. We've improved power, response as well as boost control ability featured in the latest SS2.
up coming for trail: TD06SL21G featuring current 74mm SS2 compressor assembly. Take effects of this compressor behavior from the SS2 it should be able to pump through greater volume of air through out of the external gate in combination with the SL2 turbine. If the end result comes out same as the SS2 then we should have a L2 based turbocharger that has the identical response to a 20G while making more power then a 25G with fatter mid range torque.
I've handed over two drawings of additional billet compressor wheels to be cut, this is relating to the SS-4 development. Those wheels are engineered to produce the 450~500rwkws range, My injectors are maxing out and needs cams. but do let me know if any one is interested for the trail and I can work out a special price.
feel free to bang through your map and i will have a look over it if your still chasing neddies.
  • Like 1
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
