Sarge can u hear it pinging? Does it happen on high boost?
What are the afr's doing?
Can't hear anything from the engine bay over the exhaust, the windows up doesn't help. Another thing that doesn't help is the fact that I cant make it happen every time. I can go to the same stretch of road where Ive pinged before, use the same gear, same start speed, same throttle and then no pinging. Its also hard to keep an eye on the AFR but on boost it goes down to about 12 and into the 11's. Ive tried to log it with the laptop but when I put the laptop down in the passenger seat and I drive over a bump in the road the USB cable comes jiggles and I lose connection. Really need someone in the passenger seat and a private stretch of road so I can test it out. Ive watched videos describing what ping would sound like. Some people say its the sound of metal chains dragging behind the car while some would bang a hammer on a piston and say that is what you will hear. Not sure what to make of it. Its not the easiest thing to fang second to redline and listen for ping in a skyline lol.
maybe not enough throttle enrichment? I had that issue when I smashed the pedal here and there, I added in more throttle enrichment and it went away (just from my personal experience)
Its got some throttle enrichment in there and when I do quick stabs at the throttle the afr richen up abit. Its not the stabs which cause the det, seems I can push the car from 2000 - 6000rpm but it gets into a danger zone at around 6400 rpm.
Take up Jez on the offer and let him have a crack on the dyno. Don't risk your motor TRYING to make it ping on the road.
Yeah Ive been speaking to him, about it. I intend on selling off the current ECU and setup and going with an adaptronic or Haltech plugin. It does seem silly trying to induce knocking especially when its just for logging sake and I know I can't do anything to try fix it.
On a side note, anyone interested in a Z32, PFC, hand controller, greddy profec b sii and the fc edit :P Can't afford the new ecu and tune otherwise.
Edited by SargeRX8
Remember it can be false knock. The stock sensors arent perfect. So u dont see the knock go up in datalogit?
How high do u see on the h/controller?
Is the dash light flashing?
I agree with GTScotT sarge, take JEZ up on the offer dude.
I challenge you to find another tuner who will put your car on the rollers for free.
I have yet to find anyone that puts the extra free time and effort in like JEZ does :)
He actually cares about how a cars running when it leaves his shop.
JEZ is the man :thumbsup:
be nice if we had someone like jez up this way ! :-(
Where you located? Road trip? :P
Free tuning? Lets go!!
We all wish :yes:
Dash lights flash 3 times and when I see that happen thats when I remember to check the hand controller when I park at home. Usually the number is between 85 - 99. Never had a chance to pickup knock in the datalogit.
Edited by SargeRX8
99! Pffft.
That's nothing sarge (I AM joking dude)
Mine was hitting the 120+ mark, I have heard it once and it is not a sound I would like to hear often.
Makes you ass clench a few times lol
That is odd.
Have u tried high boost. It will go in a different part of the map, curious if it pings on high boost. Does it do it only after a hot run?
Time for wmi or e85 sarge :)
Just make sure if u run wmi dont run the wmi out... Hey Dave :P
Not necessarily after a hot run. I had the car parkes for about 30 mins after a 15 min drive. Gave it a squirt and the flashing light took away from the fun. E85 or flex fueol is where im heading. Wmi is just another thing that could potentially go wrong. Introducing another independant system would scare me lol. I think the flex fuel is the way to go. I tried that octane 100 with 5 or 10% ethanol content and it gave me a slightly better fuel consumption rate and I recall not a single ping event on that fuel. Get ready jez ill be heading up your way soon.
That is odd.
Smartass! :)
I could always blame the boys who put the fluid float switch in lol
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
