Here's controlled run from today. The maximum power reached was 445rwkws with 25psi @ 4500RPMs.
No, its not responsive for a daily, how ever not bad considering the peek power it managed. This is our base run using standard cast compressor wheel, my billet wheel versions will be act against the result above, and the desired out come would be for better power and response. 460rwkws with 25psi by 4300RPM would be a nice goal to reach
Is that using a ball bearing core? Looks quite reminiscent of a typical .82a/r cast GT3582R result
Yes this is a ball bearing core, this turbocharger is direct replacement of a XR6 BA so it is in fact same as a 3582R.
We did comparisons against an actual 3582 in .82 rear on RB25det, they are roughly 400RPMs laggier, which is similar to the Thick yellow curve from few weeks ago, how ever not a lot of differences in terms of power delivery curve.
Those cams, I have a feeling that they've made the car laggier compare to stock items, Which I'm aware SR20dets do pickup quite a bit of lag by going larger.
Stao do you mean to say that this core was tested back to back with a 35R and it was found to be 400rpm laggier OR was the genuine 35R laggier?
The genuine 3582R was laggier. It was spot on to the none VNT boost curve.
First prototype is installed. Feels like I just gained even more power without better response.
the .70 is even laggier. I've trailed both on road. However .70 housing should give me little bit more top end. The run above is running a .50 cover. The other run compared to was a GT3582 in a .82 turbine which I presume in a .70 comp.
This is a base run to compare the billet wheels with. Not all drawings works and some performed worse then standard. So this is a base curve to compare to.
Hey all, i fitted my SS2 internal gate to my car and dump and it appeared it was all fine but trent from chequred tuning just tried to tune my caar and said the wastegate flap is getting stuck closed as it is fouling on the dump pipe. My dump pipe is a JJR Bellmouth item exactly the same as this http://justjap.com/store/product.php?productid=18178
Has anyone had an issue with this before, as i cannot remember reading about it anywhere. Just wanting to make sure it is this before i pay to have it fixed and find it's not the issue. Trent said he ran it up on the dyno and it went straight to 30psi hahahaha
I'm aware the JJR's dump don't match gasket 100%. Here's a small tutorial on how to fix it:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__6340
Or could be the stud is to long unless the lever is hitting on the outside part of the dump pipe. did Trent had a play or unload the actuator? Unhook the actuator and see if it can be opened freely by hand.
What sort of power did it make on 30psi?
be interesting if during you ss4 development you could grab one of those
gtx3540 copy billet wheels that are for sale everywhere to throw into the mix
to see where your wheels stand next to a gtx3540
be also interesting if once you found you perfect comp wheel for the ss4
if you then tried it with a gt3788 type turbine to see what effect it had on
the comp wheel with less backpressure
cheers
darren
Im not really sure mate didn't get much info bar the wastegate having no boost control. I will mension this to him tomorrow and see what he has to say and report back :)
Annoying only finding it once it went onto the dyno >_<
cheers
darren
Well the larger the blades are engineered the more HP it makes and laggier it gets.
I'm retrieving the size of the wheel while increasing the blade size for better response. 450rwkws is plenty, I want it to delivery the power in a away that is smooth and drive able as daily.
Please ask Trent to unhook the actuator and see if the gate free moves by hand. If so then just unload the actuator and see if the boost controlling device is working.
I believe this is as responsive as I can get a 3540 to be in its original form by altering its housing while not trading off the top end power.
Since the configuration of the housings are set, I will then work on the wheels matching up the same sort of HP while not trading off response. Pretty much all other compressor wheels are developed based on the same way.
Some update from tuner Toshi. This is the first result from our updated highflow profile, Which has a set of customized wheels.
quoted from Toshi's thread: R33 Hypergear R33 hiflow turbo, Z32 ecu nistune 241kw at 15psi
Looks like its out of injectors, at 20psi it is expected another 20~25kws gain.
HxhBLzW.jpg?1?7643
I'm not too concert about peek power, however quite pleased with its boosting behavior. In which it did manage to hold straight to red line without tapering.
For power and response on RB20det SS1 or SS1.5 .64 is perfect and made for that engine. Those two are highly recommended over high flowing. Alternatively yes we can also high flow the stock turbocharger to be responsive which will be maxing around 200rwkws mark.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
