Lithium Posted September 2, 2013 Share Posted September 2, 2013 Here's controlled run from today. The maximum power reached was 445rwkws with 25psi @ 4500RPMs. No, its not responsive for a daily, how ever not bad considering the peek power it managed. This is our base run using standard cast compressor wheel, my billet wheel versions will be act against the result above, and the desired out come would be for better power and response. 460rwkws with 25psi by 4300RPM would be a nice goal to reach Is that using a ball bearing core? Looks quite reminiscent of a typical .82a/r cast GT3582R result Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7000270 Share on other sites More sharing options...
hypergear Posted September 2, 2013 Author Share Posted September 2, 2013 Yes this is a ball bearing core, this turbocharger is direct replacement of a XR6 BA so it is in fact same as a 3582R. We did comparisons against an actual 3582 in .82 rear on RB25det, they are roughly 400RPMs laggier, which is similar to the Thick yellow curve from few weeks ago, how ever not a lot of differences in terms of power delivery curve. Those cams, I have a feeling that they've made the car laggier compare to stock items, Which I'm aware SR20dets do pickup quite a bit of lag by going larger. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7000441 Share on other sites More sharing options...
GTScotT Posted September 3, 2013 Share Posted September 3, 2013 Stao do you mean to say that this core was tested back to back with a 35R and it was found to be 400rpm laggier OR was the genuine 35R laggier? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7000831 Share on other sites More sharing options...
hypergear Posted September 3, 2013 Author Share Posted September 3, 2013 The genuine 3582R was laggier. It was spot on to the none VNT boost curve. First prototype is installed. Feels like I just gained even more power without better response. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7000870 Share on other sites More sharing options...
raZ1911 Posted September 3, 2013 Share Posted September 3, 2013 More lag than the XR6 3582R with the .5 housing or the "real" 3582R with the .70? Also will you experiment with a billet wheel at some point? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7001527 Share on other sites More sharing options...
hypergear Posted September 3, 2013 Author Share Posted September 3, 2013 the .70 is even laggier. I've trailed both on road. However .70 housing should give me little bit more top end. The run above is running a .50 cover. The other run compared to was a GT3582 in a .82 turbine which I presume in a .70 comp. This is a base run to compare the billet wheels with. Not all drawings works and some performed worse then standard. So this is a base curve to compare to. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7001732 Share on other sites More sharing options...
GeorgesR34 Posted September 4, 2013 Share Posted September 4, 2013 Thats pretty decent response for power. looking forward to it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7002921 Share on other sites More sharing options...
iruvyouskyrine Posted September 4, 2013 Share Posted September 4, 2013 Hey all, i fitted my SS2 internal gate to my car and dump and it appeared it was all fine but trent from chequred tuning just tried to tune my caar and said the wastegate flap is getting stuck closed as it is fouling on the dump pipe. My dump pipe is a JJR Bellmouth item exactly the same as this http://justjap.com/store/product.php?productid=18178 Has anyone had an issue with this before, as i cannot remember reading about it anywhere. Just wanting to make sure it is this before i pay to have it fixed and find it's not the issue. Trent said he ran it up on the dyno and it went straight to 30psi hahahaha Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003381 Share on other sites More sharing options...
Marcus89 Posted September 4, 2013 Share Posted September 4, 2013 I have the same dump on my ATR43 G2.5 and haven't had any issues Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003426 Share on other sites More sharing options...
hypergear Posted September 4, 2013 Author Share Posted September 4, 2013 I'm aware the JJR's dump don't match gasket 100%. Here's a small tutorial on how to fix it: http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__6340 Or could be the stud is to long unless the lever is hitting on the outside part of the dump pipe. did Trent had a play or unload the actuator? Unhook the actuator and see if it can be opened freely by hand. What sort of power did it make on 30psi? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003472 Share on other sites More sharing options...
jet_r31 Posted September 4, 2013 Share Posted September 4, 2013 be interesting if during you ss4 development you could grab one of those gtx3540 copy billet wheels that are for sale everywhere to throw into the mix to see where your wheels stand next to a gtx3540 be also interesting if once you found you perfect comp wheel for the ss4 if you then tried it with a gt3788 type turbine to see what effect it had on the comp wheel with less backpressure cheers darren Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003628 Share on other sites More sharing options...
iruvyouskyrine Posted September 4, 2013 Share Posted September 4, 2013 I'm aware the JJR's dump don't match gasket 100%. Here's a small tutorial on how to fix it: http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__6340 Or could be the stud is to long unless the lever is hitting on the outside part of the dump pipe. did Trent had a play or unload the actuator? Unhook the actuator and see if it can be opened freely by hand. What sort of power did it make on 30psi? Im not really sure mate didn't get much info bar the wastegate having no boost control. I will mension this to him tomorrow and see what he has to say and report back Annoying only finding it once it went onto the dyno Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003665 Share on other sites More sharing options...
hypergear Posted September 4, 2013 Author Share Posted September 4, 2013 be interesting if during you ss4 development you could grab one of those gtx3540 copy billet wheels that are for sale everywhere to throw into the mix to see where your wheels stand next to a gtx3540 be also interesting if once you found you perfect comp wheel for the ss4 if you then tried it with a gt3788 type turbine to see what effect it had on the comp wheel with less backpressure cheers darren Well the larger the blades are engineered the more HP it makes and laggier it gets. I'm retrieving the size of the wheel while increasing the blade size for better response. 450rwkws is plenty, I want it to delivery the power in a away that is smooth and drive able as daily. Im not really sure mate didn't get much info bar the wastegate having no boost control. I will mension this to him tomorrow and see what he has to say and report back Annoying only finding it once it went onto the dyno Please ask Trent to unhook the actuator and see if the gate free moves by hand. If so then just unload the actuator and see if the boost controlling device is working. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7003831 Share on other sites More sharing options...
iruvyouskyrine Posted September 4, 2013 Share Posted September 4, 2013 No worries mate will get onto Trent tomorrow and see what he says about it. Thanks. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7004127 Share on other sites More sharing options...
jet_r31 Posted September 4, 2013 Share Posted September 4, 2013 gotcha stao, so instead of maximium flow with that turbine with maximium response, the brief is 3540 comp wheel flow with maximium response? cheers darren Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7004320 Share on other sites More sharing options...
hypergear Posted September 5, 2013 Author Share Posted September 5, 2013 I believe this is as responsive as I can get a 3540 to be in its original form by altering its housing while not trading off the top end power. Since the configuration of the housings are set, I will then work on the wheels matching up the same sort of HP while not trading off response. Pretty much all other compressor wheels are developed based on the same way. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7004717 Share on other sites More sharing options...
hypergear Posted September 7, 2013 Author Share Posted September 7, 2013 Some update from tuner Toshi. This is the first result from our updated highflow profile, Which has a set of customized wheels. quoted from Toshi's thread: R33 Hypergear R33 hiflow turbo, Z32 ecu nistune 241kw at 15psi Looks like its out of injectors, at 20psi it is expected another 20~25kws gain. I'm not too concert about peek power, however quite pleased with its boosting behavior. In which it did manage to hold straight to red line without tapering. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7009500 Share on other sites More sharing options...
Missileman Posted September 7, 2013 Share Posted September 7, 2013 What about the RB20 highflow, is there an update planed for it? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7009537 Share on other sites More sharing options...
hypergear Posted September 7, 2013 Author Share Posted September 7, 2013 For power and response on RB20det SS1 or SS1.5 .64 is perfect and made for that engine. Those two are highly recommended over high flowing. Alternatively yes we can also high flow the stock turbocharger to be responsive which will be maxing around 200rwkws mark. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7009582 Share on other sites More sharing options...
hy_rpm Posted September 7, 2013 Share Posted September 7, 2013 Cause it's running only 14-15psi boost See what happens over 20psi Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/437/#findComment-7009807 Share on other sites More sharing options...
