Stao does that then mean the water lines etc will line up perfectly or will they be the same as my current SS1PU.
I had a huge headache with the r33 organising the oil return and the water lines when fitting it so I thought if I stuck with the stock setup for the R34 then I wouldn't have that issue again.
The SS1PU has the smaller bearing housing. So they are same the as earlier version.
G2/SS2 and larger versions runs the larger T3x bearing housing. Those are easier to install. Best to have a look at the installation walk through for both in page 1.
Can reuse factory compressor end, not the turbine end. Which gives it a factory look.
Birds. For the drags you will need some 275 MTs, run them at 18psi, and worm them up nicely. If the launch is perfect then a good time is more promising.
One thing I didn't like about Heathcote is how they washes rubber residuals at the start of runway with water every time a car lunches. So we always taking off on wet tires.
They do that at all drag strips, just go around it...
I can't fit 275s without some serious bubble; I only have 9 inch wheels and they come out quite wide to the guards already :(
Can anyone with an SS1PU and a Z32 AFM please check their peak AFM voltage on WOT (preferably 3rd of 4th gear) ??
Stao if you can ask Trent for this that would be great also.
Thanks,
I'm running the 275 on 9.5 inches wheels in 17 inches. You can get them to fit.
By the way, I've found a local company whom's happy to produce the braided oil lines at a much cheaper price. as well as the quantity that we are producing. I'm happy to deduce $100 off all High flow jobs as we as none special priced listed items.
Means your high flow job is now $860, and SS1PU/SS2 is $1350 all including oil lines.
Also we are a little over stocked with our billet SS2.5's parts. Now offering cheap for $850 each complete turbocharger with oil line.
C'mon Stao you're killing me, having bought a regular price SS2 just last week ;)
Great prices people, get on em!
Thanks,
No members with an SS1PU want to help out a member who does his best to help everyone he can? :(
I don't have a multimeter sorry mate
If you have a powerFC it will show on the handjob (hand commander), or it will show if you have the software for a nistune if thats what you run.
If anyone has access to either of the above with the same turbo please let me know what reading they are getting at WOT in higher gears :) peak reading.
Birds don't you run a PFC with your SS1PU?
Lol awesome, that's hilarious :)
Good luck for the weekend, will be interesting to see!
Yes indeed, in fact all the guys at tires joint were beating wither this is car has an intercooler or an oversized radiator. I just made 1 person $100 richer today, no one thought this is a turbocharged kia. Ended up with some 225 / 65 / 16 Nitto tires. Still wheel spinning and torque steer all over the places. MT don't make any tires in this size.
How ever this result might give a little indication of what the SS1.5 would do on a SR20det motor, knowing the .64 might be a little chockish, this is running a .86 FNT rear with a 66mm compressor. We were been able to add an additional 5 degrees of timing compare to what it was in the .64 rear. Because the additional timing down low and up top, we ended up picking up 40kws with out getting additional lag.
At about 20psi this turbo would be an idle turbocharger for a SR, with similar response to a Disco.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
