The injectors are good. haven't experienced any issues yet.
What have you run them with? Does Trent have any feedback?
Even my tuner knocked them, but he didn't realise that I was running a set.. I find it funny because he made such a point to tell me how good EVERYTHING in my car was, in that it gave him ZERO issues. I guess that includes the injectors, :P right?
It should be known that I get great economy and perfect drivability with them AND my awesome Hypergear turbo.
question was in regards to the five 0 motorsport side feeds,
but thanks anyway
Lol just got back on the forums and skipping a lot of sections, my bad :blush:
Just chucked my 1000s in and set them up on the pfc and idled perfectly like stock so far so good next week will see how go on the tune.
  • Like 1
Awesome news dude. Be sure to get feedback from your tuner and post up.
Well that's the thing. The pattern should directly effect the quality of the burn, but my plugs say my motor runs mint.
I am not convinced they do have a bad pattern. I am more so thinking there is a fall back policy being made should they become pooey later in the life cycle. Sort of like an 'I told you so' for when you come and say 'my cars not right'.
Plug condition won't always tell the story. The quality of the atomisation can affect things like how prone the engine is to detonation and therefore how much you can lean on it during tuning and ultimately how much power it makes. If you have a good, wide and fine spray pattern then you end up with decently even mixture distribution. If you have a rough and coarse spray, then you will get regions in the cylinder that are richer and leaner than they should be, which will will all average out in the wash (ie the overall burn is the right mixture and so the plugs don't show any bad signs), but mean that you can't lean on it as hard.
AFR at the tail pipe I agree, comes out in the wash, but effect on the plug I disagree.
The plug is in the very cylinder which you yourself said will have rich and lean zones, causing heat spots and therefore risk of detonation. That would show on the plug, rather than having a perfectly clean electrode and a nicely carbon dusted outer, especially after a very wide range of unforgiving driving.
No, my point is that it won't detonate if you don't push it to. Better injectors means that it can be pushed harder. In both cases the tuner stops pushing before he sets it up to fail, but the better injector'd case will be making better power. There may be slight differences in the plugs from the differences in mixture distribution, but surely no-one can read plugs that well that they'd be able to tell that one set of injectors was better than they other. If they're not melted and they're not all black or badly whitened, then they'll just look like plugs.
The thing is a poor spray pattern has to have some negative effects, otherwise why would it be considered bad and why would engineers try to design injectors with better atomisation? Not dating it would be a huge effect, but there has to be one.
Edited by superben
But wheres the actual proof that the fiveomotorsport ones have a poor spray pattern? from what ive heard everyone thats run them on various cars has always said they are great. Its true there are dodgy hiflows out there but doesnt meant all of them are.
Best way to prove this, there's a trader on this forum that's got a stand at WTAC and will happily assess your injector's spray pattern for free at WTAC.
Speaking of injectors don't buy deatschwerks , they pop and misfire like crazy at low duty cycles, great power with no det, decent economy (14-16L/100km with 260kw) but yeah pop pop pop at idle and cruise.
Edited by Rolls
Which Deatschwerks are you using, the older high flows or the current generation ones ( like these http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det )? I have a set of 800cc high flows with SS2 and a similar power level. The only popping I'm getting is occasionally when lifting off rapidly on high boost. They seem to idle fine.
nah...rolls has the 740 sidefeeds iirc...
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb25det/1993-98-rb25det
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
