The injectors are good. haven't experienced any issues yet.
What have you run them with? Does Trent have any feedback?
Even my tuner knocked them, but he didn't realise that I was running a set.. I find it funny because he made such a point to tell me how good EVERYTHING in my car was, in that it gave him ZERO issues. I guess that includes the injectors, :P right?
It should be known that I get great economy and perfect drivability with them AND my awesome Hypergear turbo.
question was in regards to the five 0 motorsport side feeds,
but thanks anyway
Lol just got back on the forums and skipping a lot of sections, my bad :blush:
Just chucked my 1000s in and set them up on the pfc and idled perfectly like stock so far so good next week will see how go on the tune.
  • Like 1
Awesome news dude. Be sure to get feedback from your tuner and post up.
Well that's the thing. The pattern should directly effect the quality of the burn, but my plugs say my motor runs mint.
I am not convinced they do have a bad pattern. I am more so thinking there is a fall back policy being made should they become pooey later in the life cycle. Sort of like an 'I told you so' for when you come and say 'my cars not right'.
Plug condition won't always tell the story. The quality of the atomisation can affect things like how prone the engine is to detonation and therefore how much you can lean on it during tuning and ultimately how much power it makes. If you have a good, wide and fine spray pattern then you end up with decently even mixture distribution. If you have a rough and coarse spray, then you will get regions in the cylinder that are richer and leaner than they should be, which will will all average out in the wash (ie the overall burn is the right mixture and so the plugs don't show any bad signs), but mean that you can't lean on it as hard.
AFR at the tail pipe I agree, comes out in the wash, but effect on the plug I disagree.
The plug is in the very cylinder which you yourself said will have rich and lean zones, causing heat spots and therefore risk of detonation. That would show on the plug, rather than having a perfectly clean electrode and a nicely carbon dusted outer, especially after a very wide range of unforgiving driving.
No, my point is that it won't detonate if you don't push it to. Better injectors means that it can be pushed harder. In both cases the tuner stops pushing before he sets it up to fail, but the better injector'd case will be making better power. There may be slight differences in the plugs from the differences in mixture distribution, but surely no-one can read plugs that well that they'd be able to tell that one set of injectors was better than they other. If they're not melted and they're not all black or badly whitened, then they'll just look like plugs.
The thing is a poor spray pattern has to have some negative effects, otherwise why would it be considered bad and why would engineers try to design injectors with better atomisation? Not dating it would be a huge effect, but there has to be one.
Edited by superben
But wheres the actual proof that the fiveomotorsport ones have a poor spray pattern? from what ive heard everyone thats run them on various cars has always said they are great. Its true there are dodgy hiflows out there but doesnt meant all of them are.
Best way to prove this, there's a trader on this forum that's got a stand at WTAC and will happily assess your injector's spray pattern for free at WTAC.
Speaking of injectors don't buy deatschwerks , they pop and misfire like crazy at low duty cycles, great power with no det, decent economy (14-16L/100km with 260kw) but yeah pop pop pop at idle and cruise.
Edited by Rolls
Which Deatschwerks are you using, the older high flows or the current generation ones ( like these http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det )? I have a set of 800cc high flows with SS2 and a similar power level. The only popping I'm getting is occasionally when lifting off rapidly on high boost. They seem to idle fine.
nah...rolls has the 740 sidefeeds iirc...
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb25det/1993-98-rb25det
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
