Sharing a couple of results:
This is the recent SLSS2 run based on a Stock Rb25det with injectors, Brae high mount and 50mm gate on E86 final run or 356rwkws @20psi
ATR43SS2 None VCT E85 Bolton version internally gated on factory exhaust manifold
21U R33 high flowed turbocharger 265rwkws on P98 fuel, running factory actuator. A high pressure actuator has been installed, looking forward to updated result.
talking about turbos coming loose a few pages back, anyone tried the atomic Anchorlox yet?
cheers
darren
First I'd heard of them but I don't see them being any better than ordinary locking tabs, aside from the fact you can reuse them. If anything they look to take up a lot of space.
  • Like 1
Anchorlox look promising, price is high. GCG offer the same gear for more acceptable coin. The nuts and Belleville washers available from Ralliart for the Evo are top notch but also priced accordingly.
That SLSS2 setup looks to deliver far more linear than the ATR43SS2.
Boost plots are way different which would account for the mid range torque whack the ATR43SS2 provides. Maybe the Brae manifold flows much nicer up high because it's like the thing isn't being strangled? Keeps making torque past 6000rpm.
How do they compare for real world driving and response?
Also, will eventually have results for my old SS1PU on a mates car now. He put it on his stock motor S15 with an external gate. Am not sure if he plans to run cams but he should beat my result due to the gate.
Preliminary testing indicates with the VCT he has not noticed any loss in spool (no extra lag to stock), and on 10psi he has already started gaining power vs the maxed out T28 that was on it prior.
I will update for records when available.
The SLSS2 is designed as an externally gated turbo, that particular reading has the advantage of external gate and Brae manifold, they do stretch power and torque figure a lot further. On same platform, they performs very closely as they all have identical compressors.
Unfortunately most of SS2 results shown are running as stock boltons. It also appears that Neo motors, probably due to their cams, they can fetch power and torque further into the high PRM regions compare to standard R33 Rb25det motors.
Notice the behavior of this is a Neo motor with a bolton SS2:
Result could be from E85 as the tuner has forgotten.
Yeah i would say the dofference is in the manifold and ext gate as i run the atr43ss2 also with brae mani and ext gate and my curve is very similar to that SL curve.
thankyou for that information, the stage 8 stuff from gcg is a a lot cheaper
cheers
darren
The minimum amount of boost I run on the OP6 turbine was 19psi and that was 320rwkws on E85, internally gated. details are at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-461
Woohoo, it's in! Loving gate atm, just running 0.5 bar at the moment till I work out what ecu I get. Will hack up the stock shield tomorrow and heat wrap the screamer, it's a tiny bit loud lol
  • Like 1
Patience hahaha, I will :)
Spent today tuning my mates S15, made 197kW on Mainland dyno. Stock turbo and the works, I've talked him into a SS1.5 in a T2 flange. He might so it soon :)
Thanks for that mate
Can't wait to get everything sorted so I can send it off to you for a high flow
Got my R34 OP6 turbo here waiting for a visit to Stao, looking forward to seeing your results. Which profile are you going with?
Just the standard high flow profile.
Currently have a SS1PU on my 33
But I want the 34 to be looking as stock as possible so that I don't get any attention from the po po. It will be running on an adaptronic with flex tune
Actually that's a good question.
What would be the benefits of a SS1PU over a high flow on a standard 98 tune?
Back in the day it would have a better top end but now days the high flow seems to be getting better results.
As you know I am a major devotee to the thread and product (even though I'm not personally using one anymore), and in my opinion the current highflow is one of the best options available.
I would buy a 2iu highflow over an SS1PU, and I would buy an op6 highflow over an SS2. Internal gate, bolt on.
I would go the SS2 if I was investing in the supporting mods to aim for 350, but not otherwise.
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
