hy_rpm Posted March 20, 2014 Share Posted March 20, 2014 No the std evo 9 turbo with cams and supporting mods have no issue at holding 25psi till redline on my brothers car evo 8 before he got it flowed by Tao The ss1.5 is even larger more like 20g size Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234267 Share on other sites More sharing options...
hy_rpm Posted March 20, 2014 Share Posted March 20, 2014 Only difference is there twin scroll larger housings and he had a 18psi actuator Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234277 Share on other sites More sharing options...
Lithium Posted March 20, 2014 Share Posted March 20, 2014 With cams or a stock head? Compare power levels, not boost numbers to get an idea of what the turbo is usefully flowing Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234282 Share on other sites More sharing options...
GTSBoy Posted March 20, 2014 Share Posted March 20, 2014 It's a system. Compressor + engine + turbine determines if the compressor will run out of flow or not. Put a small back end on and you may not run out of compressor flow and so hold boost to the redline. Put a larger rear on it, relieve the back pressure on the engine, might be another story entirely. I like the analogy used on here the other day (in some thread or another) about comparing apples and oranges to work out which is the best banana. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234313 Share on other sites More sharing options...
Ben C34 Posted March 20, 2014 Share Posted March 20, 2014 That was Lithium's analogy. I also found it perfect for summing up a lot of comparisons you see on the net. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234357 Share on other sites More sharing options...
Dose Pipe Sutututu Posted March 20, 2014 Share Posted March 20, 2014 Some update, did some tuning last night and ramped it up to 1.1 bar already.. appears my stock injectors are about to hit a brick wall. I've dialled in more fuel however I've notice I had to add in heaps to get it under 11.8 AFR. For those interested, attached is my fairly relaxed timing map I tried to add more timing after 5000 rpm, but experienced some knock around the 5200 ~ 5600rpm part (which does't make much sense as I'm past max torque). Will check my CAS again. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234378 Share on other sites More sharing options...
scotty nm35 Posted March 20, 2014 Share Posted March 20, 2014 Stock injectors, lol, why didn't you get me to ship a set of 550 sidefeeds up with the housing Johnny? Or a top feed rail and 1000's? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234382 Share on other sites More sharing options...
Dose Pipe Sutututu Posted March 20, 2014 Share Posted March 20, 2014 ^ hahahhaa.... I'm on a budget man, this Adaptronic ECU was super impulse buy @ $700 ! I was planning to stretch Toshi's remap till after the financial year, but this was too tempting LOL NAOOO to top rail, CBF.. too much effort LOL Can you get 1200cc OR 1000cc sidefeeds? we can talk after my tax returns haha Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234405 Share on other sites More sharing options...
hypergear Posted March 20, 2014 Author Share Posted March 20, 2014 I have a spare set of brand new FiveO 1200 CC for $750 if interested. The 16g is abit small for what I was after, might be shifting that to the SS1 turbine and see which one is better out of the two. I will be evaluating the current 18.5 or 20.5G billet comp wheels down the track. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234419 Share on other sites More sharing options...
scotty nm35 Posted March 20, 2014 Share Posted March 20, 2014 The only side feeds I can get are the 550's, as that's the largest they made from the factory. Anything larger is a 'highflowed' injector, essentially drilled out. Top feed rail and Xspurt 1000's are an easy upgrade, and would cost around the price of the FiveO injectors alone. Local warranty can come in very handy too, it can cost more than the injector is worth to send it back for warranty replacement. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234439 Share on other sites More sharing options...
hy_rpm Posted March 20, 2014 Share Posted March 20, 2014 Stock head and s1 cams Made 256awkw on 25psi now his aiming for 300awakw with his slss2 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234440 Share on other sites More sharing options...
Dose Pipe Sutututu Posted March 20, 2014 Share Posted March 20, 2014 The only side feeds I can get are the 550's, as that's the largest they made from the factory. Anything larger is a 'highflowed' injector, essentially drilled out. Top feed rail and Xspurt 1000's are an easy upgrade, and would cost around the price of the FiveO injectors alone. Local warranty can come in very handy too, it can cost more than the injector is worth to send it back for warranty replacement. hrmmms.. let's see after tax returns The bank account isn't happy at the moment, from my impulse buy lol Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234449 Share on other sites More sharing options...
hy_rpm Posted March 21, 2014 Share Posted March 21, 2014 Look at the housing size difference between a t28 and evo 9 turbo Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234514 Share on other sites More sharing options...
hypergear Posted March 21, 2014 Author Share Posted March 21, 2014 No the std evo 9 turbo with cams and supporting mods have no issue at holding 25psi till redline on my brothers car evo 8 before he got it flowed by Tao The ss1.5 is even larger more like 20g size Actually the SS1.5 is smaller then a 20G. That one which you've sent back originally was a 20G size. Regardless the compressor don't matter that much, the turbine side is the one needs to be worked on. The SLSS2 stopped making power at 385rwkws at 23psi on my R33 externally gated on high mount. Usually smaller engines needs more boost getting the same power level. How ever the EVO is internally gated (stock manifold?) The easiest way to determine wither the turbocharger or some thing is maxed out is by judge the amount of power gain per psi of boost added. The percentage starts to decline sharply when that happens, and best leave as that. By calculation this the SLSS2 will max out at 299awkws at 29psi. Did that evo ended up adding higher boost for the dyno show? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234525 Share on other sites More sharing options...
hy_rpm Posted March 21, 2014 Share Posted March 21, 2014 Well it advertised off kando as a std evo9 16g6 but billet Even though it was a 20g it was responsive 25psi by 3600rpm But even people with the standard cast evo 9 turbo get the same results My bro evo should be coming back today from tuner got head stud installed aswell as 30psi Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234590 Share on other sites More sharing options...
GeorgesR34 Posted March 21, 2014 Share Posted March 21, 2014 Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234779 Share on other sites More sharing options...
Lithium Posted March 21, 2014 Share Posted March 21, 2014 Stock head and s1 cams Made 256awkw on 25psi now his aiming for 300awakw with his slss2 What fuel? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234824 Share on other sites More sharing options...
GTScotT Posted March 21, 2014 Share Posted March 21, 2014 Well it advertised off kando as a std evo9 16g6 but billet Even though it was a 20g it was responsive 25psi by 3600rpm But even people with the standard cast evo 9 turbo get the same results My bro evo should be coming back today from tuner got head stud installed aswell as 30psi Keen to hear the SLSS2 results, please update! I thought the recent post to Evo Oz was actually SLSS2.. So it was actually the Kando thing? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234827 Share on other sites More sharing options...
hy_rpm Posted March 21, 2014 Share Posted March 21, 2014 Nah it was a kando evo 9 turbo with billet wheel to start off with but then he was after 300awkw so I sent it to Tao to get hi flowed to slss2 It's on eflex fuel Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234876 Share on other sites More sharing options...
GTScotT Posted March 21, 2014 Share Posted March 21, 2014 So the result posted to Evo Oz was just the Kando billet, right? You haven't posted SLSS2 results yet? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/477/#findComment-7234899 Share on other sites More sharing options...
