It's a system. Compressor + engine + turbine determines if the compressor will run out of flow or not. Put a small back end on and you may not run out of compressor flow and so hold boost to the redline. Put a larger rear on it, relieve the back pressure on the engine, might be another story entirely.
I like the analogy used on here the other day (in some thread or another) about comparing apples and oranges to work out which is the best banana.
  • Like 1
Some update, did some tuning last night and ramped it up to 1.1 bar already.. appears my stock injectors are about to hit a brick wall. I've dialled in more fuel however I've notice I had to add in heaps to get it under 11.8 AFR.
For those interested, attached is my fairly relaxed timing map :)
I tried to add more timing after 5000 rpm, but experienced some knock around the 5200 ~ 5600rpm part (which does't make much sense as I'm past max torque). Will check my CAS again.
^ hahahhaa.... I'm on a budget man, this Adaptronic ECU was super impulse buy @ $700 !
I was planning to stretch Toshi's remap till after the financial year, but this was too tempting LOL
NAOOO to top rail, CBF.. too much effort LOL
Can you get 1200cc OR 1000cc sidefeeds? we can talk after my tax returns haha
I have a spare set of brand new FiveO 1200 CC for $750 if interested.
The 16g is abit small for what I was after, might be shifting that to the SS1 turbine and see which one is better out of the two.
I will be evaluating the current 18.5 or 20.5G billet comp wheels down the track.
The only side feeds I can get are the 550's, as that's the largest they made from the factory. Anything larger is a 'highflowed' injector, essentially drilled out.
Top feed rail and Xspurt 1000's are an easy upgrade, and would cost around the price of the FiveO injectors alone. Local warranty can come in very handy too, it can cost more than the injector is worth to send it back for warranty replacement.
hrmmms.. let's see after tax returns :)
The bank account isn't happy at the moment, from my impulse buy lol
No the std evo 9 turbo with cams and supporting mods have no issue at holding 25psi till redline on my brothers car evo 8 before he got it flowed by Tao
The ss1.5 is even larger more like 20g size
Actually the SS1.5 is smaller then a 20G. That one which you've sent back originally was a 20G size. Regardless the compressor don't matter that much, the turbine side is the one needs to be worked on.
The SLSS2 stopped making power at 385rwkws at 23psi on my R33 externally gated on high mount. Usually smaller engines needs more boost getting the same power level. How ever the EVO is internally gated (stock manifold?) The easiest way to determine wither the turbocharger or some thing is maxed out is by judge the amount of power gain per psi of boost added. The percentage starts to decline sharply when that happens, and best leave as that. By calculation this the SLSS2 will max out at 299awkws at 29psi. Did that evo ended up adding higher boost for the dyno show?
Well it advertised off kando as a std evo9 16g6 but billet
Even though it was a 20g it was responsive 25psi by 3600rpm
But even people with the standard cast evo 9 turbo get the same results
My bro evo should be coming back today from tuner got head stud installed aswell as 30psi
Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on.
Keen to hear the SLSS2 results, please update!
I thought the recent post to Evo Oz was actually SLSS2.. So it was actually the Kando thing?
    • Rust repairs completed, doors back on! pretty much totally back together running now. All future repairs will be fiddly wiring getting everything back up to road condition.  hasn’t  taken that long considering the condition I got the sub. note my helpers keeping the back seat warm 😂
    • SAU NSW Old Pac Cruise to Newcastle All Japan Day 2025 Sunday 27th July 2025 5:00AM Meeting Berowra Station Commuter Car Park 2 5:15AM Departure Cruise Via Old Pacific Hwy 7:45AM Arrival to Lambton Pool (Regroup) 8:00AM Arrival to Newcastle All Japan Day 2025 Meet Location: Berowra Station Commuter Car Park 2 Stop 1: Lambton Pool (Carpark) Final Destination: McDonald Jones Stadium for Newcastle All Japan Day 2025 Tickets: Newcastle All Japan Day 2025 $20 Per Car Spectators Free PURCHASE TICKETS HERE *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • SAU NSW Attends Machines & Macchiatos Cars and Coffee Sunday 13th July 2025 7:00AM Meeting Davidson Park 7:20AM Departure 7:45AM Arrival at Northern Beaches Christian School Meet Location: Davidson Park Final Destination: Northern Beaches Christian School Machines & Macchiatos Tickets: $10 Per Car $2 Spectators Pay at Gate LIMITED SPACES Register Below to Reserve your Spot. Members Receive Preference REGISTER HERE   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
