Posting a little update. This is the SS2 based ATR28 turbocharger with a even larger turbine. This particular one runs off ceramic roller bearings. Hopping to get 300rwkws+ with 20psi by 4000RPMs.
That housing is nearly all turbine lol Surely that cant have a good nozzle area? You must have lost heaps when machining it to suit the turbine.
That's fine. You just need another one of my patented unspacers.
But seriously.....what size turbo is that manifold designed to hold up? For it to place it so close to the cam cover is a bit, um, wrong.
Edited by GTSBoy
Well I purchased it off someone on this forum stating it was for an RB25 and he planned to put a GT3582 on it. I bought it unused, maybe there is a reason it was unused....
I'm on my mobile at the moment so I can't search but surely it's not the turbo that's the problem? There would be pics of peoples high mount SS2 but I can't find them.
It would have to be the manifold I'm sure of it.
lol that is very wrong. The turbine is in a standard T3x patterned housing, means other T3s will have similar issues. I use Brae high mount and fits perfectly.
Definitely a problem with the manifold. I would say the jig used to make it would likely be overused and out of shape.
There is nothing unusual about the size of an SS2, its definitely not going to be much larger than a GT30/35 based turbo.
I have an ss2 low mounted on a 6boost manifold with no issues. Comp housing is a bit close to the engine mount bracket but no issues at all
That manifold is odd. If someone was going to run that sort of manifold with an ext wastegate an ss2 should not be an issue at all. Looks like youd need to have a stock turbo for that to work......
If its a 6boost then call or email kyle. Probably best to email him with some photos and give him your number. He might be able to give you an answer or organise an exchange of some sort
I think it make similar power as your GTX3071 hopefully with better response. If that works well I will enable VCT.
Taking consideration that my SS1PU made 30kw less than your test car (at the time on p98 w/cams) before it was maxed out, I am going to apply the same reduction to my GTX. In the end my car pulled the MPH to support happier numbers so I believe that's fair.
Just putting that out there before we compare the results from the 2. My car is a complete back to back, I have only changed the manifold and turbo. Considering I went to T3 high mount I should have more lag than you.
We will compare results soon enough. I'm sure they will either drive sales for yourself or give you something new to strive for
Most gtx3071r I've seen on sr20 are slightly laggier than the old gt3071r
Gt3071r 20psi by 4000rpm
Gtx3071r 20psi by 4500rpm
Both highmount t3 .63ar
But while the gt3071r will struggle to make 300rwkw on pump98 the gtx3071r will make that quite easily on 20psi and a lot more with more boost and e85 330-350rwkw
My results on my car with the ss1.5 were almost the same but I was on e85 his was one pump
For 20psi boost I made 250rwkw and he made the same but on pump 98
With 5 psi more down low and taper up top he got 270rwkw but he has a aftermarket manifold and step 2 cams mine is std manifold and poncams
E85 usually gives a 20kw gain on the same boost level
The difference would be the cams. I've compared mine with few that has Pon cams at Trents, The BC cams are making in average of 15kws more mid-top while the pon cams has 15kws more in mid-low with better response.
The GT3071 on my car hits 20psi by 4250rpms at 250rwkws, feels laggy down low.
Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
