that kia must be a laugh to drive....throw some m/ts on the front and go down the princes highway on a friday night...
cheers
darren
About 1 launch and youd snap something lol
Thought there might be some more interest in this thread,
I'm selling an SS1 I recently purchased for my RB20. Need the cash unfortunately.
http://www.skylinesaustralia.com/forums/topic/441479-sa-hypergear-ss1-turbo-brand-new/
Here my dyno results from my ss1.5 on my sr20det non VCt 180sx
266rwkw ss1.5 .86ar
250rwkw ss1.5 .64ar
251rwkw atr28g2 .64ar
Power vs boost
Power vs torque
Tuner said there was 5-10kw more in it if I replaced my dw300 fuel pump for a walbro 460lph pump as fuel pressure was dropping 10psi under load when tested but not worth the money and extra to tune right now as turbo is at it's max and injectors will be too as I'm on e85
The .86ar did gain 16rwkw but at 250rpm lag penalty and 5psi more down low and 2-3psi more up top
So it did make the engine happier as he could add in lots more timing and more boost
where as before I was capped to 20psi with .64ar or he had to remove lots of timing with more boost to the point power went down with more boost
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Is this internal or external gate. Far out there are so many options haha, and I have the exact same mods and I'm getting it done at pulse racing... May save me some time
Drives a lot nicer now it's tuned to the .86rear
Part throttle still has power but haven't done a lot of driving yet as I just got it tuned
But I was surprised it didn't lose much response going from the .64 to .86 200rpm if they where both on 20psi was expecting it to be worse and laggier about 500rpm but engine is a lot happier
Should have waited alil longer as the atr28ss2 would have been a lot better everywhere and make more power down low and up top
This is an internally gated bolton upgrade turbo that sits on factory manifold, dump, and water lines. It is an very responsive turbo for around the 260rwkws mark on P98 fuel. Alternatively you can run the new SS2 which would be good enough for 300rwkws on pump 98 fuel.
I'm missing something - I think his is on E85 and it maxed out making just over 260rwkw? Or you mean 300kw @ hubs?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
