Anyone care to share pics of their SS2 high mounted on an RB25? Preferably on a 6Boost manifold.
Also stao, can you run a rear turbine housing like the one on the T67 (which goes straight to Vband and doesnt have your 5 bolt IWG/EWG adaptor) on the SS2 at all? I test fitted a GT3076 on the 6BOOST manifold and it fitted fine but the SS2 front housing hits the cam covers.
I email'd Kyle (owner of 6BOOST) and sent him some pictures and measurements of the manifold. His response was that all manifolds come off the same jig and mine isnt any different to a standard item. He also said
"At a guess id say the hypergear turbine housing is bigger or the offset of the scroll closer to the flange centerline making it bulge out the rocker cover side more and hit. Borrow a proper Garrett turbo off someone and try it.
Regards, Kyle"
looks like you've got 3x options really:
  • Get Stao to get you another exhaust housing, something a little shorter so it brings the turbo down
  • Modify the manifold (probably worst option)
  • Get a Garett Turbo (probably close to worst option also)
Regards, Kyle"
That is BS
Ask him why other people using his Rb25det high mount manifold and this particular turbo fits.
All P Trimmed T3x turbine housings are identical. Its the "Area" over Radius that made up that volume which hits the rocket cover. To space it out, this area will have to be minimized, means no longer .82.
Also look how close this back plate is to the head. There is no way this comp housing can fit even the turbine housing is changed.
I've seen 6 boost manifolds high mounted SS2 with .82 turbine before. This manifold is very wrong.
The only way I see it, is by cutting off the manifold flange and re-weld it in the correct angle.
Surely people can understand my situation. I have 2 reputable people (Hypergear and 6Boost) both telling me that it's not their product that is at fault. I just want to know what my issue is.
That's why I asked for pictures of other people setups to be 100% sure that the turbo is fine.
If you look at thr manifold, the angle seems pretty aggressive so it brings the turbo closer to the head.
Can't be the turbo, all the exhaust castings are the same. If that's the case then every single turbo Hypergear sells would need different manifolds each time, however every turbo fits as it supposed to low or high mounted.
Even look at Cal's SS2, has been mounted in the most unconventional way and fits.
It's no big deal to cut and shut the flange to angle it away from the head, but obviously Kyle is unwilling to do that? Poor service indeed... You could possibly machine it, or weld a wedge shaped flange to the top?
I suggest you take it to another fabricator and never speak of 6boost again.
<p>looks like you've got 3x options really:
Another option would be a custom made angle spacer, between turbo and manifold.
Which would be weird! I can help out there if needed.
Edited by superben
383rwkws with 23psi by 3500RPMs standard spec rb25det engine on single scroll high mount and external gate E85. Thats about the limitation of most power and response. any thing more it starts to chock the engine down low and doing opposite. It feels as stock turbo pulling 383rwkws. No point getting any better response beyond this point.
That was with the old SS2 CBB CHRA, the new one can probably fetch 390rwkws.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
