Received my billet ss3 for Hypergear a few weeks ago
Can not wait to finish fitting it up to this 58,000k originally bone stock auto motor
And run it it my daily driven and weekend tracked Silvia
Will update again when the results are in, excited is an understatement I have big hopes for this package
  • Like 1
Generally I see Rb20det engines using the same turbocharger been 1000RPMs laggier then as if its used on a RB25det engine.
So the SS2 Alpha mentioned above should be making full boost around 4500RPMs on a Rb20det, power based on same boost is about 10% less up to certain point that RB20dets no longer makes power while RB25dets keeps on making power.
I email'd Kyle (owner of 6BOOST) and sent him some pictures and measurements of the manifold. His response was that all manifolds come off the same jig and mine isnt any different to a standard item. He also said
"At a guess id say the hypergear turbine housing is bigger or the offset of the scroll closer to the flange centerline making it bulge out the rocker cover side more and hit. Borrow a proper Garrett turbo off someone and try it.
Regards, Kyle"
Bugger....out of interest is that a new manifold or used?
Brand new, completely unused. It should be known that i bought it off another member of this forum unused as well, not direct from 6boost. Just my luck though :(
Anyone have a pic of there 6boost on cause from pics the angle of the manifold definitely doesn't look right.
That's what i was thinking, that's why i asked for pics. I was looking for your engine bay manuel but couldn't find it, i'm sure there is a pic in this thread somewhere.
I did toy with the idea of an angled spacer, or cutting the flange off and remounting at a different angle but the inside is all die grinded smooth at the collector and its all really nice. Would rather not do that but if i have to.......
Actually an angles spacer would suck as the nutss would contact the turbo at the wrong angle.
Cut off re weld, has to be done.
It can be ground again smooth.
Edited by superben
The thickness of the flange to the head and what appears to be some scale on the manifold made me think it may be. An easy option would be bolt the manifold to a dummy plate, grab an oxy and lever it 5-10mm. Heat the right places and science will do much for the work for you. Much easier than cutting and welding
that sux balls dude, but superben is on the money...it can be made pretty again...just cut and reweld the flange at the right angle....then ...make it pretty and make ceramic coat it.
Yeah my pics is here but my manifold is brae not 6boost but here it is anyway.
Decided not to paint my cam covers blue today thinking it would be too try hard and wouldn't look too good so I went with black and then I see this picture. Damn you, that's so nice! lol
Had my rb20 tuned yesterday with Unigroup.
OP6 Highflow.
240rwkw, 20 psi, full boost around 4800rpm. 98 fuel.
Ran out of time to adjust cam gears, tuner thinks he can get approx 500rpm better response.
Car still uses stock r32 airbox, return flow cooler, engine bay looks stock.
Comes on hard, is lots of fun to drive.
Car makes some cool spool noises from inside :) Very happy so far.
Will post dyno graph up tonight, left it in the car.
4800rpm from an OP6 highflow on an RB20 is fairly reasonable I believe, also making the right power for a bolt on for an RB20.
If Yavuz thinks he can dial it down another 500rpm and not lose any power that would make for a pretty good bolt on result. Props.
Nice power, that's gotta be fun - though 4800rpm is pretty nasty, even for an RB20.... hopefully that spool can be improved as suggested as it's not that flash at the moment at all, imho.
Hmm, I don't think its that bad man. A stock OP6 is pretty laggy on a 20, so I don't anticipate a highflow to be much better.
Not to say that 4800rpm is great spool but I do think its on par.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
