Thanks
Is the ATR43ss2 a lot bigger or ok for what I'm looking at? Don't mind going external gate, prob off exhaust housing.
This is for a track car.
go SS2 with the external hanging off the turbo.. I get full noise around 4100rpm in 3rd and it's on E85.. it is a touch bigger.. I would say 3076R size, but a touch more responsive.
hasn't seen a dyno yet, but Virtual Dyno tells me my shit box is making 317kW lol... however other cars have made over 350kW on stock cams with the same turbo.
I bash mine around the track quite often but takes getting used to.. the massive surge of power usually gets the car sideways (even with a 2 way).
Firstly sorry for being lazy. But what is the best direct bolt in turbo for an R33 gts on E85 shooting for around 400rwhp with as much response as poss. Or is it worth going external gate and or big dump?
Standard high flow will do that fine.
I'll be tuning the internally gated one on BP98 with a Dynapack hub dyno, probably not as tough an audience as you guys are overall used to - though similar to some. Will probably go for around 18psi, but will see how knock limited it is and decide whether to go higher from there.
Attatched is my completely standard unopened 25 with internal gate SS2 on stock manifold and plenum, 1000cc injectors, Gtr intercooler, 3" exhaust, NISTune and 98PULP tuned on a hub dyno 21psi bleeding to 18.
  • Like 2
Whats full boost? 4100rpm in 3rd sounds less responsive than a GT3076R if anything
Yeah that is definitely laggier than a GT3076R - not bad for the price, that they seem to make similar power and the fact that they are a journal bearing turbo... goes well when you add up the costs of buying and installing one :) I look forward to experiencing it in person though and seeing what they're all about!
Yep, I'm probably the last person you need to tell that to :) I never ran 20psi deliberately so admittedly I can't quote exactly what I ran there but used to hit ~1.1bar around 3700rpm in 3rd quite happily so I doubt it is any worse.
4th was a different kettle of fish altogether (would hit 17psi before 3500rpm):
:whistling:
Anyway - I (obviously) think the SS2 are a good thing, hopefully will have a better idea of how good soon... but I definitely like to keep it real, as well. Considering the price and convenience difference I think they deliver very very close to one of the most popular Garrett options.
yo Lithium, if you want I can do some logs tonight and send them to you :)
Also I do have my gain set conservatively on the EBC - I find on the track it does like to spike a little thus my boost might seem a touch laggier.
I know I can get 1bar around 3500~3700rpm - just can't remember exact numbers...another thing to factor in E85 will make turbos a little lazier as the EGTs are lower but highly doubt it's noticeable lol
  • Like 1
First I've heard of lazier boost response on e85 due to lower egt. ....
another reason why some tuners prefer running lower timing as the car comes on noise to increase EGTs to get the turbo moving
The cooler exhaust temp is obvious. The xtra exhaust volume due to burning more fuel still resulting in a slower spool is surprising.
Stao's examole was 100 rpm later.
So do you guys use soft timing zones to try and induce better spool?
For 98RON I tend to make timing lazy to get it to spool harder, but with E85 I just smash in as much timing as possible to produce the most torque as possible for that RPM.
More torque = more exhaust flow, however all my experimentation is usually graphed in Virtual Dyno or "feel".. will be hiring a dyno soon to finish off my tune.
Here's my current timing map, quite a bit of timing through the motor - but she loves it.
It's not that you're burning more fuel. The amount of moles of exhaust gas is more closely related to the amount of air that the engine breathes. Granted, ethanol produces more H2O and less CO2 compared to petrol, and so there is definitely an increase in total number of molecules. Total mass of exhaust is also higher because of the extra mass of fuel involved. But there is definitely lower temperature, which not only impacts (downward) the actual volume flow rate of gas, but at the same time the total enthalpy of the gas and the velocity of the gas.
I haven't done the maths, and I'm not going to unless we turn this into a proper argument, but you could easily enough calculate the change in moles between the fuels, and given an assumption of a typical 98 and E85 exhaust temp for an otherwise the same engine load (say what? 75C?) you could calculate the actial volume difference, velocity difference, and with a bit more work the enthalpy difference. I think that most of us (inlcuding me) would be hard pressed to say how much of an effect the latter 2 of that list would actually change spool, and not very many more would be able to estimate the spool difference for the first 2 either. But you could look at the % changes and decide if you think it would cause the effect on spool to be +ve or -ve.
  • Like 1
Proper argument, proper argument !!!!! :D
I would be interested to see the math on this, and there is extra %s for showing the workings :D
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
