Yes that Mac solenoid went funny on the start and we could not run any thing less then 23psi. it was later replaced. High boost was tuned first then low boost. I think this is what blew one of my Rb25det engines few years ago.
Ok there's possibly a few things going on there that make direct comparison difficult. What difference/similarity in spec between those 3 for exhaust manifolding, exhaust system, inlet pipe/filter, and intercooler/piping?
The two GTRs are very similar, R32 had a 6boost high mount, same size cooler that was supplied and installed by the same fabricator. the GTST had hybrid NZ manifold and the usual cross over pipe front mount cooler kit.
All cars has factory cam gears, while the GTST has VCT. All tuned on the same dyno using the same ramp parameters.
Wasn't hard to guess. They are junk and all block with E85. I don't know why people bother
I bet I have put more tanks of ethanol through my set than anyone, without any issues...
Blaming your injectors for a poorly filtered fuel system is a little silly isn't it?
Been speaking to Stao but I'll ask anyway:
Which turbo would be recommended for ~100rwkw at 3,000rpm / full boost by 3,000rpm and around 240rwkw?
If possible a bolt-on solution which retains the stock 21U housings.
How long have you left e85 sitting in the rail for as we had an evo at my shop never had an issue ran on e85 for a few years now, left to sit for around 6 months and when starting idle was shit house and wouldn't rev right, afrs f**ked. All injectors were gunked up, dropped in a new set of the same ones (Id's) and back to perfect. Only issues I've seen if when the cars been left sitting for long periods of time. Running lots of fuel threw em and not having it sit generally gives no issues
There are few persons that I speak to that had issues with gunk blocking injectors, they all appears to have the type of injector that has the four small spray holes on the nozzle. The ID Bosh single ping spray type of injectors seems to be less problematic.
All EV14's?
Not all, the Bosch branded ones that are around $100 from Sonic performance seem to have issues.
Ummmm no. I have never had a set, I've always used Deatchwerks without issue but going to events and watching my friends competing have 3 sets of injectors for when they block is fairly amusing.
I've seen around half a dozen different cars all with issues of these injectors blocking, all with different and more than adequate filtering systems. One car evern changed filter set ups 3 or 4 times and still had issues, funnily enough swaped to a different type of injector and never an issue since.
If you have these injectors and they work that's great for you but don't you run Xspurt? I'm yet to see a car with these injectors on E85 that don't have issues
Edited by SimonR32
Time for a dedicated thread on these issues I reckon?
I'm thinking Scott Black's on the money here. Sounds broadly similar to what happens with methanol - the hardware doesn't cope well if the fuel is left to sit in tanks and lines. Maybe not in all instances with E85, but reports are common enough and seem to involve those cars being left to sit between events and maybe running a few times per year.
I'd like to hear what happens for those guys who drain their tank and purge the system with petrol.
add some Lucas Ethanol stabiliser into your tank, I do that and last time I removed my injectors they were clean as the day I got them..
Also note, I do like 3000km per year on my car - it doesn't get driven much.
My car did sit around for about 3 months when i did the transplant to another shell with a different tank that hadnt had e85 in it before.
So i think it was a combination
1. Car sitting around for longer than normal
2. New tank hadn't run e85 before and was sitting around even longer than 3 months.
3. I dont run filters on my EV14s
I have the SS2 and while it would be pretty close to 100rwkw at 3k (it's between 95 and 100) full boost isn't made until around 3700-3800. I'd probably go the highflow for those targets. The OP6 highflow has been over 300rwkw a few times with E85 so you do have a bit of head room if you wanna turn it up
Had the OP6 highflow on pulp, it was good up top but not as responsive as I wanted. I think I'm gonna get an SS1 built into the factory housings. Should have similar response to an SS1PU according to Stao. Full boost by ~3500rpm and ~90-100rwkw at 3,000rpm.
250rwkw is more than enough for me on the street. Response is what I'm ultimately after.
Edited by colourclassic
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
