Have a feel of shaft play, there should be about 1mm side to side and nothing in / out. If that is the case check for lose bits thats bolted to the turbo.
Noticed you are in Melbourne, Call and drop by for a quick inspection when you are free.
  • Like 2
Thanks Stao PM coming your way.
Just finished installing my 21U high flow and had it tuned by Trent:
Much happier with the performance of this turbo compared with the OP6 variant I had last time.
As you can see, full boost is achieved by under 3,500rpm and I got 100rwkw at just over 3,000rpm.
My car's clutch began slipping towards the end of the tune, so Trent backed the power off; it could have made 260-270rwkw with more boost.
It's currently making 248rwkw at ~16psi. It feels better than my OP6 did at 20psi and 270rwkw, probably due to the wider spread of power/torque.
Big ups to Stao for this turbo and for putting up with my constant calls,visits and questions! :thumbsup:
Edited by colourclassic
  • Like 3
Thanks for the feed backs, always happy to help and the power curve looks great.
For 200rwkws by 4000RPM, the SS1PU would do it pretty well, or the 21U high flow can also do that assume you run enough boost at it.
11042955_864656746927801_611170638299213
10429303_864656813594461_292470324094080;;
11034300_864656860261123_504551220440252
Installed, housing mod by scotty, rest of welding im finishing up now myself. screamer is done, just gotta lengthen cooler piping to joiner and weld on a nipple for wastegate reference and we're good to go. can't wait to see how the SS2 goes.
They stops making power around 23psi. I was getting 327rwkws internally gated, but 367rwkws externally gated.
I completed a turbo install plus few other bits on the R34 today. They do give you a lot more useless stuff then they've done on R33s. Few things to point out:
I usually preload my actuators to 4mms. if for what ever reasons it has been removed and re-installed, please make sure it is loaded to where it was. More preloads can be added In case of boost tapering at high RPM on big boost.
The oil feeding line sits in between the turbo and chassis, do not fold them in between the turbo and manifold. The braided oil line is standard with and high flow services and is usually supplied with an ATR43 series turbochargers. Make sure you do get one if a 2nd hand turbo of ours is purchased.
Split fire coil packs are must in most of cases for high boost:
Most of people uses a JJR bell mouth front pipe, so I've bought one my self.
and its not quite right, but for the price I won't complain.
and gasket on our turbine housing is perfect:
Give it a little die-grinding and its ok.
The turbo in there is a SAT version of the ATR43G3 with a factory housing machined to suit. This is also the first internal gated version of that model, turbo comes in smooth and responsively. Still need to get a metal intake pipe made, the car will be running an Adaptronic plugin, hopefully hitting 300rwkws on pump fuel.
  • Like 1
Can you keep the AFM, as most people do. So if you are doing more like for like testing it would make sense.
Some feedback for you stao.
> Stock untouched RB30E bottom end
> Stock untouched RB25DET Neo head
> VCT
> Hypergear ATR43SS2 (mid 2013 model)
> 6boost exhaust manifold
> Turbosmart 45mm hypergate (7psi spring) venting to atmo
> 3" straight through exhaust
> E85
> Adaptronic R34 GT-T select plug in
> X-Spurt 1000cc injectors
> R32 GTR intercooler
First impressions are that its so much fun everywhere in the rev range. Comes on to boost very fast in the upper RPM as you would expect, lower RPM is still pretty quick but has room to improve.
The cam timing is slightly out and I didn't have time to get a degree wheel and set them perfectly to zero, the gate is only running a 7psi spring at the moment which makes it a little lazy also.
Once I get back on the dyno and fiddle with both intake and exhaust cams (both are now adjustable from the front thanks to Ben C34) and chuck a 14psi spring in the gate it should be quite a monster. Can't upload the boost graph for some reason. 10psi low boost and 13psi high at the moment. I assume this is not even reaching the turbos efficiency range yet? I haven't seen anyone run such low boost using one of your turbos haha.
It's quick enough for me already but I really want to go back fix the cam timing, bigger gate spring and chuck 20+ psi at it and see what it makes hahaha.
nice, what do you think is causing your waveness on your graph lines? if thats only 13psi then thats pretty awesome! what power is normally achievable with GTR intercooler?
Edited by Badgaz
> VCT
> E85
> R32 GTR intercooler
Looking promising so far will really come on when you wind a few more psi in.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
