Yes its in the video. Here's one more customer's video. I believe this is an ATR43SS-2 running 20psi internally gated. Making 294rwkws on pump 98 fuel.
The stag now rests in Donny @ Forced Motorworx capable hands. To say I'm a little excited is an understatement.
here's some more R33 vs. SS2 love, but this one is externally gated - had to turn down the boost to 1.3bar during the day as the head was lifting at 1.6bar LOL
  • Like 2
Nice video footage. :)
This is a set of rather unusual high flow jobs. Pair of high flowed 2860-5s into ATR28SS15. Its going to a Rb30det engine with Rb26 head. Hopefully they will solve the back pressure issues currently experiencing with GTRS turbine wheel. One more thing that I'm alittle concern is the back pressure in the exhaust system as the ATR28SS15 is ideally made to run on a single 3 inches turbo back system, that GTR is pretty good of having 4 inches turbo back exhaust, still have to be shared with two turbo how ever. I've made some oversized thrust collars for that purpose, hopefully be seeing close to 500rwkws with those once fully running.
One more prototype of SAT prototype is made for my single high mount GTR. This one was engineered to make around 450awkws on the current setup without additional lag. It made huge amount of torque, and clutch is gone. This one will definitely be making alot more power, and response is no different to the traditional SAT. Nismo Super coppermix is going in, hopefully be back on the dyno in two weeks time.
Vs standard ATR45SAT (pink and yellow is from the new prototype, stopped when clutch gave away)
I noticed you have removed the divider between the turbine outlet and the wastegate, just curious of the thinking behind that ?
The exhaust is twin 3" through twin 3" cats into single 4" at the mid muffler then 4" out the rest, back pressure from exhaust shouldn't be an issue :)
  • Like 1
The rear wheels are bigger, once machined the divider turned out to be very thin. Since the compressors are lot bigger also, it will create greater turbine flow. Usually internal waste gates don't at full 90 degrees, the divider would limits the amount of bleeding area around the disc resulting unlimited boost creep, that is some thing else I had in concerns, but I won't know till they are in the car and running.
My recent RAC speed event.
SS2 ~410hp
Despite my over steer incident, my best time of the day.
Great footage :thumbsup:
I figured there would be a reason, was just curious as to what it was and figured it might have to do with get gases away from turbine, unfortunately I run split dumps and will have to put something back in there so the split dump works the way it is meant to :/
Yep, these are mine and are replacing my GT-RSs in the hope of gaining some response and allow me to run more boost to see if I can crack 500awkw, currently at 458awkw @ 28psi
Cool! I remember drunk conversations at Mick's place a couple of years ago playing around with ideas like this - we were discussing FP based similar solutions, but this works. Will be very interesting to see how it comes out :)
I still wonder/worry a bit about the housings and potential restrictions beyond the actual wheels themselves which could hamper progress but I hope they are unfounded. When do you aim to have this all together?
And by the way, I've made some custom exhaust wheels that is for the GTR OEM high flows. They are engineered to support 300 ~ 350awkws region on pump fuel and response will have similar to stock twins. My car's waiting for bits and pieces, so if any one is interested to evaluate please let me know, I will put a special offer for $1200 on both turbochargers.
  • Like 1
The twin atr28ss1.5 should have no problems cracking 500kw on your rb2630 setup
A single ss1.5 on my old sr20 made a very easy 251kw on 20psi and 266kw with a larger
.86 rear housing and 24psi
Only thing stopping you from running 25+psi maybe the back pressure from the turbines unless stao has changed them as I got mine a while ago 1-2years ago and smaller rear housing will be the best for response
I gained 16kw from going from a .64ar to .86ar but full boost went from 3750rpm to 4100rpm also 4psi more but felt faster and more responsive with the .64 ar
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
