Wow. Just caught up on 180 pages in the last few days after not visiting Sau for ages. Still an awesome thread. Some excellent improvements and results Stao!!
Finally getting my SS2 off its run in tune soon and adjust for the change in cam timing. I'll post results when I get them.
What did you mean by 'run in tune' ? I've got a SS2 that's going on soon as well
I didn't get to see the tuner the day I dropped it off. He saw it had a new motor so only set it about 17psi and not much timing. Time to put some more hurt on it now I've dialled the cams and got rid of the lag it initially had when cams were retarded.
Some updates, This is an internally gated prototype that I've been working on few weeks, the goal is 370rwkws on E85 fuel with excellent drive ability, internally gated bolton to factory RB's manifold, dump and all lines.
My final result was 365rwkws @ 23psi E85 and 330rwkws P98 @ 22psi. 20psi was reached at 3800RPM, while made over 200rwkws @ 4000 using either fuel. This is probably the highest power any one has every made using a bolton turbo. I'm very happy with todays results.
R34 GTT RB25DET NEO unopened engine.
- Adaptronic​ ECU
- 1000CC ID injectors
- Factory cams and cam gears.
- HyperGear ATR45SAT Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
- P98 fuel @ 330rwkws
- E85 fuel @ 365rwkws
- Tuned by Trent Hewitson​, Chequered Tuning​.
Dyno below shown results on both E85 and P98 fuel.
  • Like 3
Anyone remember when the SS2 reached 20psi ? It was a while back and couldn't find it. Currently can't decide between the SS2 or new ATR45
That might I've been my dyno results im running 21psi internal gate 297rwkw on p98
4000rpm give or take a few hundred depending on mods and turbo specs
  • Like 1
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
