Wow. Just caught up on 180 pages in the last few days after not visiting Sau for ages. Still an awesome thread. Some excellent improvements and results Stao!!
Finally getting my SS2 off its run in tune soon and adjust for the change in cam timing. I'll post results when I get them.
What did you mean by 'run in tune' ? I've got a SS2 that's going on soon as well
I didn't get to see the tuner the day I dropped it off. He saw it had a new motor so only set it about 17psi and not much timing. Time to put some more hurt on it now I've dialled the cams and got rid of the lag it initially had when cams were retarded.
Some updates, This is an internally gated prototype that I've been working on few weeks, the goal is 370rwkws on E85 fuel with excellent drive ability, internally gated bolton to factory RB's manifold, dump and all lines.
My final result was 365rwkws @ 23psi E85 and 330rwkws P98 @ 22psi. 20psi was reached at 3800RPM, while made over 200rwkws @ 4000 using either fuel. This is probably the highest power any one has every made using a bolton turbo. I'm very happy with todays results.
R34 GTT RB25DET NEO unopened engine.
- Adaptronic​ ECU
- 1000CC ID injectors
- Factory cams and cam gears.
- HyperGear ATR45SAT Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
- P98 fuel @ 330rwkws
- E85 fuel @ 365rwkws
- Tuned by Trent Hewitson​, Chequered Tuning​.
Dyno below shown results on both E85 and P98 fuel.
  • Like 3
Anyone remember when the SS2 reached 20psi ? It was a while back and couldn't find it. Currently can't decide between the SS2 or new ATR45
That might I've been my dyno results im running 21psi internal gate 297rwkw on p98
4000rpm give or take a few hundred depending on mods and turbo specs
  • Like 1
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
