Some good figures out or a R33 AUTO, P98 fuel using our 21U STD high flow making 262rwkws @17psi. Usual bolton mods, Tuned By Boosted brothers in SA.
If it got 262kW out of a 21U at 17psi, what do you think a SS2 at 18psi with usual bolt ons would achieve ?
My ss2 on an unopened 186k/km neo made 265kw at 18 psi with boost leaks and top end restrictions using basic boltons
That result isnt a 21u housing...
its a Auto C34 Rb25 Neo RWD.
Its a 0p6 housing.
But it still is a GREAT result...as the car has a stock plastic turbo intake pipe haha .... , a stock op6 turbo actuator.. and a just jap return flow cooler....and a bleed tap..
if it was manual.. it would be 280rwkw on 17psi..
cheers
darren
Ok, cool. Here's some thing quite extraordinary. I found my previous run using the ATR45SAT int gated prototype had a collapsed rear muffler.
Had that replaced and, it went up to 380rwkws then run out of fuel. My Walbro fuel pump played up shortly after as it started to run lean and leaner after each dyno run.
Without the extra back pressure boost creeped to 23psi up top, its not perfect at this stage. More development will be conducted. But 380rwkws out of internally gated bolt on turbo is a pretty good result. With the extra fuel I'm pretty certain it will reach very close to 400rwkws.
  • Like 1
This is getting beyond ridiculous. 380kw out of a literally 'bolt on' turbo with very minimal supporting mods. I can't believe some of the stuff you are putting out recently stao, incredible work mate.
  • Like 2
What's up with the Walbro mate? Should be good for 450ish. Better check the hose intank, was the relief valve between the pump and lid removed? I bet if you replace the dodgy fuel filter the 34's run you will find extra flow, did Trent try bypassing the filter on the dyno?
I removed the fuel filter and replaced it with a straight piece of metal pipe, made no difference. It started to run lean, and leaner. The voltage to it was fine, the pump has now been replaced, I'm hopping to see this issue solved on my next dyno run. similar scenario happened to my R33 two years ago, except that pump just stopped, left me on roadside for a few hours.
Don't get another
That's great advice, I have sold hundreds without issue. Best intank on the market, but most cheap out on the wiring. These need a 70amp relay and decent wiring like anything that draws 25+ amps.
The chances the pump is at fault are pretty slim. Most likely your relay is flogged Tao, try a direct power feed.
Stao, is that the same turbo I have? The ATR45SAT?
Oh, and is that on pump or E85?
Hi, I'm not sure. This is probably the only internally gated prototype ever built. Yours could be an externally gated model or a SS2 internally gated, best refer to order list. It managed 353rwkws on pump before running out fuel. But at 23psi of boost the car was pretty happy with timing and happier to take on more boost. With every thing working it should be maxing out towards 400rwkws E85 or about 370rwkws on pump.
On top of that the turbo it still makes 20psi by 3800RPM and over 200rwkws on either P98 or E85 @ 4000RPM, it makes a pretty good daily.
Just checked, it's the ATR43 G4.
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
