What's different about the new SS2? Will it be keeping the same response? Mine is a late 2012 unit and I'm wondering whether it's time to send it to you for a refresh.
Also I'm running mine external gated (45mm hypergate) with a 25/30 neo setup. Made 265kw on 10psi and 292kw on 13.5psi.
Going for retune on Tuesday and upped gate spring to 14psi and will be running more boost now. Will post back with results ;)
^ oneday il be calling on you for guidance on how to build a 2530 neo, if wer following trend it should make more power with no loss in response.. i think thats what hes done across his range of turbos lately
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
Still very much enjoying my 2013 SS2. If I ever decide to upgrade I'd definitely look into this low mount (or the ATR45SAT if it fits :) ), together with an external gate off the stock manifold.
I reckon the NEO might need some forgies at that point though...
Stao is it possible to modify a JJR bellmouth to work without an IWG or is it best to replace the dump/front when going ext gate?
Neo on forgies oh that would be alot of fun.
When i swapped over to external gate i had my bolton and acuator asembly sent back to stao and he sent the vband housing and then you just need to put a vband on your dump and get the gate housing made on the mani.. definitely worth doing!
  • Like 1
Nice!! So the exact same turbo but with ext gate? Would you have a dyno sheet before and after by any chance?
I have an ATR45SAT sitting at home now waiting to go in. I'll probably install it in the next week or so then it gets tuned around this time next month so I can tell you how it goes. Supposed to fit on the low mount stock manifold also.
Watch this space and I'll update you when It's done
  • Like 1
SS1PU will work fine it doesn't work with a small exhaust housing like the 21U units. So it will be fine.
The new SS2 uses a different exhaust side, on dyno, compare to the previous model, its been able to take more boost with more timing. I'll still still be aiming at 20psi by 3800RPM in 4th. For predicted end result it will be some where close to 340rwkws internally gated on pump 98 fuel and close to 400rwkws on E85 externally gated.
With the capacity of most common 3 inches diameter exhausts, I will be making some small bits and accessories to come around it.
With the capacity of most common intercooler and a 3 inches diameter exhaust, but I will be making some small bits and accessories to come around it.
Do you have a picture of the exhaust housing?
hory shet... makes me want to take out my SS2 and throw it in the bin and get the new version haha..
I'm pumping 24 psi into mine and the exhaust housing glows nice and red to only makeep 340kW. And by that time, my intake air temp is over 60 degrees lol
  • Like 1
ss1pu is for 1450 same as ss2. for a r34 because of the cams and higher engine comp, down low torque doesnt change alot between the two. I will be running an ss2 instead.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
