Yes can be done. I have done a evaluation few years ago, the SL2 turbine wheel is made for external gating. It didn't work as well as the SS2 or the OP6 high flow in terms of boost control and peek power.
And how you asume that the new SS2 will be compared to the OP6 in terms of torque and response. The way i look at it, it seems that the OP6 delivers more torque then a old ss2 and about the same power, if i got it right ;):)
I have always ran my exy gate to pressure from my intake manifold what actual issues does it cause ? Mine sits with in 1.5 psi cross the lot
Let's say that you have the throttle 1/3 open and you're trying to maintain some boost pressure in the manifold (with your right foot) that is somewhat lower than the maximum boost that your boost control setup is able to give you.
Let's now consider that the signal driving the wastegate is from that (low pressure) intake manifold and therefore the wastegate is going to be clamped shut. This is exactly what the boost control system is expected to do when confronted with lower than target pressure on the signal line. So now the turbo is going to be spooling hard, driving the pressure in the pipework to some really high pressure, which is being dropped across the throttle. "So what?" you might say. Well, what if you drive the compressor across the surge line? Will that be fun? What if you pop an intercooler hose off a pipe (that you wouldn't have done if it wasn't seeing 35 psi inside)?
Etc etc. There are a number of good reasons for not sourcing the actuation signal from the plenum.
  • Like 2
Kiwi that works well and gd but u wont be seeing as much in the motor after cooler drop etc
That's the point, you want to work the turbo to give you the flat boost or targeted amount thus post intercooler but pre throttle is more desirable for a pressure source
No the number of psi going to the wastegate is irrelevant if you have a boost controller (Link controlled Mac valve in my case). The point of putting it on the compressor housing is to have quick response.
I have mine like Johnny said, in the charge pipe like factory R33 has it and I found much better boost control with my AVCR. I'll get my Haltech to do it one day
one last question here, just trying to figure out which turbo I'd like to purchase. Someone sell me either one on their experiences
Pros and Cons
Rough power figures for these two turbos
ATR45 vs ATR433SS3
Edit: I should add I'd like to see 300kw+ on 98octane
Edited by thommo458
Pros and Cons
ATR45 vs ATR433SS3
I'm making 290 with the ATR45 - Restriction is said to be cooler. I believe the ATR45 will push well past the 300s and makes great torque. Check out my build thread for details.Should give you plenty of room to go more than 300 but it's quite laggy on 98 but once it comes on it's nuts. I believe the 43 should be less laggy but have less headroom
Edited by kingtube69
the SS3 is made for external gating. for internally gated and 300rwkws+ bolton, The atr45SAT is a better turbo. Alternatively for 260~300rwkws region, you can use our ATR43SS2 for better response.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
