bilk06169 Posted December 1, 2017 Share Posted December 1, 2017 21 hours ago, hypergear said: The plan before my next dyno run is to trail PWR's vertical flow cooler as they do make one that bolt on to an R34 GTT and will be replacing the PFC with the latest Adaptronic Modular R34 plugin ECU. hi tao. i know you push pwr intercoolers alot however i need a cooler rated between 800 - 900hp the plaszmaman and pwr are similarly priced what do u recommend. im actually upgrading my atr43 to precision. i will be repeat customer because the turbo did withstand a hell of a beating ;p 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7860970 Share on other sites More sharing options...
hypergear Posted December 1, 2017 Author Share Posted December 1, 2017 I haven't personally used Plaszamaman coolers I can't comment. But PWR 600x300x79mm worked very well. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861040 Share on other sites More sharing options...
Super Drager Posted December 4, 2017 Share Posted December 4, 2017 I'm waiting to see if my trust return flow cooler will be able to hold up at 18psi (wastegate pressure). Never heard of anyone going much over 300kw with one. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861285 Share on other sites More sharing options...
Super Drager Posted December 4, 2017 Share Posted December 4, 2017 Probably way too small for the ATR45SS Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861286 Share on other sites More sharing options...
GTSBoy Posted December 4, 2017 Share Posted December 4, 2017 The top to bottom intercoolers usually have OK pressure drop, but they have poor thermal efficiency. The tubes are numerous (= lower pressure drop) but they are too short (= less cooling that longer tubes at slightly higher velocities, due to lower Reynold's number, Nusselt number, and hence h). But so long as the turbo is running efficiently and not heating the air too much, that should be OK. The only other problem I have with them is the tanks are really long and fed from one end, which is less than ideal for distributing the flow to all the tubes evenly. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861289 Share on other sites More sharing options...
hypergear Posted December 9, 2017 Author Share Posted December 9, 2017 Spent a day installing an newly purchased PWR Vertical cooler that is made for an R34 GTT, it is currently available on PWR's website. Installation wasn't as straight forward as hopped but easier then most of FMIC kits. A quick walk through for anyone that might be interested, the A/C fan needs to be removed for this cooler to fit, and the fan bracket had to be cut short. The hood lock needs to be grind down that secures to the top bracket of the cooler. Passenger side front reo bar had to be filled down missing the intercooler inlet, and the bottom mount matched up to where the radiator supports are. Overall we spent around 4 hours getting everything fit up nicely. Car's yet to be dyno tuned, but does feel slightly laggier compare to the HKS return flow kit that was originally installed. Hopefully it solves the boost drop problem and make few more KWs. 2 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861791 Share on other sites More sharing options...
Gw2 Posted December 10, 2017 Share Posted December 10, 2017 (edited) Absolutely loving reading about your progress with the r34, please keep updating us with your progress. I have a question for you if you don't mind answering. I am planning on modding my r34 gt-t which currently has the stock turbo, I'd like to upgrade to the ATR45SS, just after new year. Which ecu would you recommend for this turbo? Ideally I'd want one that keeps the traction control system working so that the tcs light isnt flashing permanently, and something that supports flex fuel. Thanks Edited December 10, 2017 by Gw2 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861852 Share on other sites More sharing options...
GTSBoy Posted December 10, 2017 Share Posted December 10, 2017 23 minutes ago, Gw2 said: Ideally I'd want one that keeps the traction control system working so that the tcs light isnt flashing permanently, and something that supports flex fuel. That'd be a Nistune. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861853 Share on other sites More sharing options...
hypergear Posted December 10, 2017 Author Share Posted December 10, 2017 This is the pressure drop test based on a Trust return flow cooler. Turbo is an ATR43SS1PU, working with RB25det Neo. The end results are all similar. GW2: We will be using the latest Adaptronic Modular ECUs, and will post results after tune. ATR45SS is a big turbo that made 490rwkws on my R33 and cracked 521rwkws on a Ford FG. This turbo do make big power but not that responsive on a Rb25det. Unless you meant ATR45SAT. This one makes up to 400rwkws on E85 with reasonably good drive ability working with Rb25det engine. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861858 Share on other sites More sharing options...
Super Drager Posted December 10, 2017 Share Posted December 10, 2017 Mine is an ATR45SS, full boost is around 4500-4600. Previous owner did 420rwkw with it. It's actually very decent for the size it is, my cousins gt2876 makes full boost at 5200rpm and only makes 279rwkw. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861883 Share on other sites More sharing options...
Gw2 Posted December 11, 2017 Share Posted December 11, 2017 Sorry yes i did mean the ATR45SAT. From what I've read and seen, it looks to be quite impressive! I will be trying to aim for 300rwkw, or get as close to it as possible. I plan on trying to keep a stock look, so i definitely love the fact that this turbo should bolt to the stock manifold. Just need to find an ecu that will not set off the traction control lights, looks like nistune might be the way to go! Your turbo kits make impressive numbers on the dyno, i am impressed Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861937 Share on other sites More sharing options...
Super Drager Posted December 11, 2017 Share Posted December 11, 2017 Sorry yes i did mean the ATR45SAT. From what I've read and seen, it looks to be quite impressive! I will be trying to aim for 300rwkw, or get as close to it as possible. I plan on trying to keep a stock look, so i definitely love the fact that this turbo should bolt to the stock manifold. Just need to find an ecu that will not set off the traction control lights, looks like nistune might be the way to go! Your turbo kits make impressive numbers on the dyno, i am impressed [emoji4]You'd be better off with a highflow for that power on e85 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861943 Share on other sites More sharing options...
Super Drager Posted December 11, 2017 Share Posted December 11, 2017 Any news on a super loud T51R slot? Like the OCD works one? 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7861944 Share on other sites More sharing options...
hypergear Posted December 11, 2017 Author Share Posted December 11, 2017 To keep factory look I can high flow your stock turbo, that makes a responsive 270rwkws on pump fuel, or I can put an stock r33 turbo's comp cover onto a ATR43SAT turbocharger that makes upto 300rwkws on P98 fuel. You will need an 3 inches metal induction pipe to do this. Back at Chequered Tuning today with Adaptronic ecu installed, VCT came back life and picked up 500RPM of response. That PWR cooler however is turning out to be an expansive disappointment showing almost the same pressure drop as the HKS return flow. Factory induction pipe was sucking shut on boost. I will use this cooler for one more dyno season with a Normal ATR43SAT turbo plus a 4 inches hard induction pipe for a comparison run to my earlier result with a FMIC kit. Boost curve shown differences with VCT engagement. 2 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7862005 Share on other sites More sharing options...
No Crust Racing Posted December 12, 2017 Share Posted December 12, 2017 Tao have you done many ATR28SS15s with BB centres externally gated? Keen to know if externally gating one is worth the hassle and whether you feel the off boost response is that much better with the BB centre, any back to back testing? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7862199 Share on other sites More sharing options...
hypergear Posted December 13, 2017 Author Share Posted December 13, 2017 Yes, but no results yet. BB delivers better throttle response in general, but not much of power increase. EXTG is definitely worth it. more power, better torque, and better boost control. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7862277 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 17, 2018 Share Posted January 17, 2018 Bringing some life into this thread and some basic data since my car is back up and running. Some quick details on the motor & turbo ATR45SAT Ceramic BB EWG Havoc Modified Stock Manifold (retains factory divider and separates pulses till about 10cm from the gate) Turbosmart 45mm Hypergate R34 NEO Motor CP Pistons Manley Rods 260 Poncams / 9.15mm Lift 85lb Performance Springs/ & Titanium Retainers R33 Intake Manifold (gay) 1550cc Bosch Injectors + usual shit 3.5" dump into a 100cell cat -> 3" axle back EWG plumb in after gate before mid muffler As per the timing map, it's pretty flat and pretty retarded (literally no timing). This map trace is from putting around and hammering the car in 1st and 2nd. Didn't load up 3rd because didn't want to put too much strain on a brand new motor with 0 kms on it. Will dump the oil this weekend and push it a bit more before I throw it up on the dyno. AFRs on boost ranged from 11~10.5:1 AFR lol... very very rich, probably not doing a new motor any favours either. Will fix that up before I punish it. Summary: Running gate pressure 0.8bar by 3600rpm in 2nd gear Boost creeps a bit due to super low timing Dose is ok for now, much more than the ATR43SS2 but not VL dose.. 4 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7865454 Share on other sites More sharing options...
AndreW_R32 Posted January 21, 2018 Share Posted January 21, 2018 hi i would love to get a G3 turbo upgrade done for my S2 R33 gtst and to make around 260-300kw mark. i have - blitz return flow fmic -dump pipe/high flow cat/ 3" straight pipe - walbro 255 fuel pump -manual boost controller -i will be installing Z32 AFM -currently stock but looking at jecs 555cc injectors / adjustable fuel pressure reg -and at the end get a nistune done unopened RB25DET i have read a lot but all so many different results some with out dyno results for proof so i come to the source hoping this will be enough to hit these numbers, cheers! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7865741 Share on other sites More sharing options...
GTSBoy Posted January 21, 2018 Share Posted January 21, 2018 Walbro 255 is going to be marginal at those power levels. Look to an upgrade. Nistune BEFORE. Not after. Why use crappy old JECS injectors? Especially if you have to buy them! Go straight to the ~720cc unmodified EV14s for 98 octane use. These will be juuuuust large enough for E85, but injectors will be near 100% or you will need more fuel pressure. Of course you will also need a rail, but it is worth it to get away from those crappy old side-feeds. Blitz return flow will start to have high pressure drop by the time you reach the bottom of your power range. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7865744 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 21, 2018 Share Posted January 21, 2018 1 hour ago, AndreW_R32 said: -i will be installing Z32 AFM -currently stock but looking at jecs 555cc injectors / adjustable fuel pressure reg -and at the end get a nistune done Install a R35 card style AFM, Z32 is "great" back in its days but suffers from reversion also eBay fakes. Convert to topfeed, even 875cc Siemen DEKA V injectors are amazing. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/600/#findComment-7865747 Share on other sites More sharing options...
