Straight up convert to top feed, use 1/2 height injectors that are stainless. The Bosch 1150cc (at 4 bar) are unmodified. Just don't use the bottom collar. These injectors are commonly referred to as Seadoo Injectors. At 3bar they're 980cc.
Or get a set of Siemens DEKA V 80lb (~875cc) short stainless injectors and a normal top feed rail. All you need to do is trim the spacers to suit. Will fit snug underneath the stock plenum too and provide you years of endless joy.
My personal best was 320rwkws on E85 fuel. This car actually made more power. Looks like its got FFP, cooler and exhaust plus fuel and ecu. It might have cams as the power curve lookes like it has no active vct.
Are there any results for the ATR45SS on an RB? I'm tossing up between the ATR45 CBB and ATR45SS CBB. Tao what would be the expected difference in lag and power be between the two? Both external gate on a proper manifold on a 30DET.
Hi, Rb30det is different to Rb25det, its heaps more responsive. Both ATR45 and ATR45SS works fine depending on how much power u r chasing for. I've personally used an 700HP ATR45SAT in a 2JZGTE no VVTI, the end result would be very similar to a Rb30det.  Car made 406rwkws @ 20psi on P98 fuel, full boost by by 4000RPM.  So what sort of power r u chasing for and will the car be running on E85 or P98?
Hi Tao,
I should add I have an ATR45 CBB 0.82 on an RB30DET (different car and engine) and have been happy with it so I know what to expect from an ATR45, just curious what the difference would be with the billet compressor. Power goals are 450 give or take 20-30 so I know both turbos are in that ballpark. Will be flex tuned on E85 in a Stagea and keeping VCT.
For 450rwkws ATR45SS-1 with 63mm billet wheel will do. Next size can do 520rwkws+ on E85 they works extremely well with XR6 BA/FA, but would be considerably laggier working with a 3L.
  • Like 1
Based on that would it be fair to expect that the SS-1 would give 20-30kw more than a normal ATR45 at the expense of 2-300rpm response? I'm just trying to figure out how it would compare to my other 30DET.
The ATR45SS-1 I'm pretty happy with and I would run that on Rb25det with a smaller rear end. when tested on the 2JZ, The response is almost identical to the normal ATR45  that made 30kws more. This particular comp wheel works with a normal ATR45 turbine.
Great result to share from Garage 7 tuned Rb25det Neo powered S14 running using one of our TD06SL205 turbochargers. This is an custom built turbo based in a TD06 rear end, externally gated.
Car has: 1000cc Injectors, Link ECU G4+ Storm Flex Fuel and usual supporting mods.
Peek power made: 308rwkw on 98 and 378rwkw on E85.
Fabrications done by: Vulcan Performance and Fabrication
Dynoed and Tuned by: Garage 7
FFP modifications done by: NDR Fab Precision Race Fabrication
Car owned by: Matt G
Sorry if a bit OT .
I was under the impression that this was a fail on RB25 plenums - or at least R33 spec ones .
Tao I'd like to hear your opinion on this one as I took your advice and fitted your preferred intercooler with a Just Jap over the fan pipe kit . It would be good to use a bend and throttle mounted on the plenum if it can be made to work properly .
Thanks in advance , cheers Adrian .
Plenty have done it and plenty say it's fine.  Many of those engines may have died, and you wouldn't hear about it if the plenum distribution was to blame because then the person who claimed it was fine would have proven themselves wrong.
But....I must stress, I don't know that it's not fine.  I only have very strong suspicion that it's not, because those plenums are not set up to receive air for all 6 cylinders from the front end.  The internal shapes are set up to receive it from the side.  I'm enough of an aerodynamicist to be very leery of that.  And I have never seen anyone report on 6x EGT probe results showing that it is fine.  On that basis, I simply wouldn't do it.  I'd be less worried about the various large plenums that bolt onto the bottom half, because at least they are simply big arse volumes on top of the runners, with no odd internal shapes to interfere.
  • Like 1
Hi, the Car's running 22psi to produce results above.
With that FFP modifications,  one of my tuners did mention it feeds CYC 5 and 6 more air then the rest causing them to run lean. I don't have personal experiences with them, so I can't comment.
    • Hey Murray, hope all is good. I took your advice and put the filler first then the putty. Seems like a much better result but i noticed there are still pinholes. I even had pin holes when i initially put the putty on the body filler. Do you think it has something to do with my spreader being f*cked? I attached some images. This is the intially body filler i sanded. No putty yet  Applying putty. Final result after using wax and grease remover can see the pin holes. I just noticed as i look at the putty application it looks wavy not sure if it's supposed to be like that or because of the spreader.
    • Hey all just wanting some advice. I’ve just compression tested my RB25det and these are the following results  Cyl 1 - 135psi Cyl 2 - 135psi Cyl 3 - 120psi Cyl 4 - 140psi Cyl 5 - 130psi Cyl 6 - 125psi   do these numbers seem ok.  Thanks in advance
    • I must say - this is how I picture all R31s!
    • Rust repairs completed, doors back on! pretty much totally back together running now. All future repairs will be fiddly wiring getting everything back up to road condition.  hasn’t  taken that long considering the condition I got the sub. note my helpers keeping the back seat warm 😂
    • SAU NSW Old Pac Cruise to Newcastle All Japan Day 2025 Sunday 27th July 2025 5:00AM Meeting Berowra Station Commuter Car Park 2 5:15AM Departure Cruise Via Old Pacific Hwy 7:45AM Arrival to Lambton Pool (Regroup) 8:00AM Arrival to Newcastle All Japan Day 2025 Meet Location: Berowra Station Commuter Car Park 2 Stop 1: Lambton Pool (Carpark) Final Destination: McDonald Jones Stadium for Newcastle All Japan Day 2025 Tickets: Newcastle All Japan Day 2025 $20 Per Car Spectators Free PURCHASE TICKETS HERE *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
