Straight up convert to top feed, use 1/2 height injectors that are stainless. The Bosch 1150cc (at 4 bar) are unmodified. Just don't use the bottom collar. These injectors are commonly referred to as Seadoo Injectors. At 3bar they're 980cc.
Or get a set of Siemens DEKA V 80lb (~875cc) short stainless injectors and a normal top feed rail. All you need to do is trim the spacers to suit. Will fit snug underneath the stock plenum too and provide you years of endless joy.
My personal best was 320rwkws on E85 fuel. This car actually made more power. Looks like its got FFP, cooler and exhaust plus fuel and ecu. It might have cams as the power curve lookes like it has no active vct.
Are there any results for the ATR45SS on an RB? I'm tossing up between the ATR45 CBB and ATR45SS CBB. Tao what would be the expected difference in lag and power be between the two? Both external gate on a proper manifold on a 30DET.
Hi, Rb30det is different to Rb25det, its heaps more responsive. Both ATR45 and ATR45SS works fine depending on how much power u r chasing for. I've personally used an 700HP ATR45SAT in a 2JZGTE no VVTI, the end result would be very similar to a Rb30det.  Car made 406rwkws @ 20psi on P98 fuel, full boost by by 4000RPM.  So what sort of power r u chasing for and will the car be running on E85 or P98?
Hi Tao,
I should add I have an ATR45 CBB 0.82 on an RB30DET (different car and engine) and have been happy with it so I know what to expect from an ATR45, just curious what the difference would be with the billet compressor. Power goals are 450 give or take 20-30 so I know both turbos are in that ballpark. Will be flex tuned on E85 in a Stagea and keeping VCT.
For 450rwkws ATR45SS-1 with 63mm billet wheel will do. Next size can do 520rwkws+ on E85 they works extremely well with XR6 BA/FA, but would be considerably laggier working with a 3L.
  • Like 1
Based on that would it be fair to expect that the SS-1 would give 20-30kw more than a normal ATR45 at the expense of 2-300rpm response? I'm just trying to figure out how it would compare to my other 30DET.
The ATR45SS-1 I'm pretty happy with and I would run that on Rb25det with a smaller rear end. when tested on the 2JZ, The response is almost identical to the normal ATR45  that made 30kws more. This particular comp wheel works with a normal ATR45 turbine.
Great result to share from Garage 7 tuned Rb25det Neo powered S14 running using one of our TD06SL205 turbochargers. This is an custom built turbo based in a TD06 rear end, externally gated.
Car has: 1000cc Injectors, Link ECU G4+ Storm Flex Fuel and usual supporting mods.
Peek power made: 308rwkw on 98 and 378rwkw on E85.
Fabrications done by: Vulcan Performance and Fabrication
Dynoed and Tuned by: Garage 7
FFP modifications done by: NDR Fab Precision Race Fabrication
Car owned by: Matt G
Sorry if a bit OT .
I was under the impression that this was a fail on RB25 plenums - or at least R33 spec ones .
Tao I'd like to hear your opinion on this one as I took your advice and fitted your preferred intercooler with a Just Jap over the fan pipe kit . It would be good to use a bend and throttle mounted on the plenum if it can be made to work properly .
Thanks in advance , cheers Adrian .
Plenty have done it and plenty say it's fine.  Many of those engines may have died, and you wouldn't hear about it if the plenum distribution was to blame because then the person who claimed it was fine would have proven themselves wrong.
But....I must stress, I don't know that it's not fine.  I only have very strong suspicion that it's not, because those plenums are not set up to receive air for all 6 cylinders from the front end.  The internal shapes are set up to receive it from the side.  I'm enough of an aerodynamicist to be very leery of that.  And I have never seen anyone report on 6x EGT probe results showing that it is fine.  On that basis, I simply wouldn't do it.  I'd be less worried about the various large plenums that bolt onto the bottom half, because at least they are simply big arse volumes on top of the runners, with no odd internal shapes to interfere.
  • Like 1
Hi, the Car's running 22psi to produce results above.
With that FFP modifications,  one of my tuners did mention it feeds CYC 5 and 6 more air then the rest causing them to run lean. I don't have personal experiences with them, so I can't comment.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
