Video footage of last weeks South Australia Time attack. Our sponsored vehicle is Topstage's carbon S14. 2015 built ceramic ball bearing ATR45SAT turbocharger survived engine failures, melted exhaust manifold, and this time fire from hydraulics fluid leakage.  Still managed to take first in rear wheel drive class.
Product update for ATR43 RB bolt on series with 3 inches dump pipe suited for Rb25det and Rb30ET.
Available using ATR / SS series as well as Garrett GT / GTX CHRA.
Housing's available in T3 .63 and .82, internal gated with 38mm port. Externally gated housings can also be supplied. More details are on our site, or simply send us a PM.
Inside the dump pipe assembly.
  • Like 2
Little video to share about Jason Ferron's drifting session at Calder park few weeks ago. Video's been put together by the Drift Junkie Andrew Sparrow, do check out their Youtube channels about he's R33 GTST build.
Jasons's car is powered by one of our high flowed R33 GTST turbochargers making around 310rwkws on E85 fuel.
that's pure turbo-porn right there.
Got my car tuned finally by DVS JEZ after having some issues with "less competent" tuners in Canberra.  I know my setup is not ideal (return-flow) but was hesitant to spend money on restrictive parts if i needed to spend money first on fundamental running issues.
Setup is as follows:
R32 Nistune ECU
EFI solutions Top fuel rail kit,  stock FPR with Bosch 0 280 157 187 495cc Injectors
Bosch Z32 AFM
3" Turbo back (bellmouth, port matched) 3" 100 cel 4" body Venom cat, straight through mufflers
Hypergear G2 21U Highflow
Greddy Profec OLED EBC
Custom Hard 3" intake pipe joining to stock Airbox, Return Bov
Return flow AVO Turboworld intercooler
R32 10psi actuator pre-loaded 3mm
GTR BOV
NPC clutch
SPlitfire coilpacks
Standard Walbro 255 with the wiring mod.
Overall result is pretty good but quoted from Jez couldn't get more out of it "too prone to detonation", note the 230kw run was abandoned. so running 223Kw on 16psi
Now i know its running right i am looking to buy a new intercooler either HDI or Plazmaman and the 5" body 100cel 3" cat and then getting the tune tidied up a bit.
My initial goal was to make the most responsive setup compared to stock turbo running 98 and airbox (hate the sound of pod filter) hence g2 profile choice. Can see my old tune in second pic of stock turbo and breathing mods.
Tao what do you think of the result? Besides changing the above (intercooler and cat)  and staying on 98 and an airbox (happy to modify it), is there anything else i can do to increase response/boost response.
Kind regards
Patrick
21 hours ago, Dose Pipe Sutututu said:
Charge temps are too high, your cat is fine.
Yeah right. Well the plazmaman street series is a bar and played and the hdi is tube and fin.
Those are the two I'm looking at at this point as reasonable options
Don't bother with the Plazmaman Street Series, they're as good as a HDi.
Get the HDi GT2 coolers, they're pretty decent for the money you're paying, yes return flows "make" power on E85 setups, because that fuel suppresses so much knock it doesn't matter how hot your charge temps (IATs) are.
Cooler air = Denser Air = Less knock
Time to cut a hole in your body work :)
  • Haha 1
The car needs a big front mount cooler,  Go for Aero flow 600x300x100mm for a good budget cooler. Also the G2 model is a factory replacement, to get more power you will need the G3 or bigger profiles.
Hi Tao,
Thanks for the response.
when I was first bought the turbo you mentioned with the right supporting mods it could make 250kw.
Reason for going g2 was wanting as close as possible to factory response as per your results below, where I seem to be making similar power but at 16-18psi instead of 13.
Did you manage to achieve above 230 with this turbo?
Guess I want to see if it's worth my while changing cooler and get the tune tidyed up a bit and try make close to 250.
Kind regards
Patrick
The highest result out of the G2 profile lot was from Dr.Drift's personal R33 back in 2010. That pulled 253rwkws on pump 98 fuel.
Sent you a pm ?
Had a chat with Dr Drift. His had a ext gate and adj cam gears. He did have a return flow though.
Sent Tao a message about upgrading to a g3 with BB
Edited by Pattey21
8 minutes ago, lexxi32 said:
11 minutes ago, Dose Pipe Sutututu said:
[mention=88652]Pattey21[/mention] hub dyno vs. roller dyno - results will vary.
Not if there calibrated properly.
If they're calibrated properly a roller will read lower due to the energy loss via the roller/wheel contact.
Also different tyres provide different readings, you run say semi slicks on a dyno make x kWs and the next day run just normal street tyres and you'll end up with a higher reading of y kWs.
  • 4 weeks later...
Tao, the new 21u basic high flow that made 342rwkw with the free flowing turbine wheel, is that as responsive as the earlier version?
How does boost response compare to the stock turbo?  Yours isn’t ball bearing so is it slightly laggier?
I have a 2860 (similar to hks2530) on the rb25 and don’t want to lose that response..
thanks
It will definitely not be as responsive as a 2860. That is too small for a rb25det.
New G3 high flow has the same response as the older version with more mod range and top end power. It is still very responsive for daily or track.
Thanks Tao,
So a g3 high flow should get about 260rwkw on an r33 p98, as opposed to a 2860 around 220-230 do you think?
How much difference in boost response? I’m getting about 9psi by about 2300rpm in 4th I think..
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
