Hi. For Rb25det, S1 turbo will do fine, no need to go for OP6. So G2 will be something that supports stock fuel system, while G3 and G4 would need to work with upgraded fuel system and programmable ecu. G3 is capable of making up to 280rwkws on P98 fuel, while G4 is capable of making up to 310rwkws on P98 fuel.
On 28/02/2020 at 12:26 PM, hypergear said:
Hypergear Atr43ss-3 Turbocharger Test and tune 474rwkws @ 28psi fuel system maxed. Should be seeing 500rwkws+ once fuel system sorted, and still seeing 265rwkws @ 4000RPM.
What's rwkw on PB98 can make that turbo? And what hotside you used on that RB25?
It looks way better than Atr45ss ?
Edited by Snara
Probably 360rwkws mark on P98, that would be a different boat compare to E85.
ATR45SS are bigger turbos, They were however tuned in 41 and 46 degrees days, I will be doing bit more work and get back to them soon.
  • Like 1
Ahh, ATR43-SS3 Make 474rwkw in this car on 28psi and ATR45SS-0 440rwkw on 28psi. I thought on e85 you can make about 10% more horsepower.
The power figure of the ATR45SS is lower then expectation, while both wheels are bigger. There is a 22 degrees difference in ambient temp differences. I will be going back to them at a later stage.
I now believe the differences of E85 and 98 is under estimated.  Without actual data of this model on P98, so Its just going to give a very rough estimate.
  • Like 1
  • 1 month later...
Some video to share from Monday's dyno tune. Car now has two Walbro 520L pumps installed with 12mm fuel lines.
Still using ATR43SS-3 turbo, except I've installed a .82 turbine housing for this particular test.The final result was 482rwkws at a point that no more power could be made with this model.
  • Like 4
  • 3 weeks later...
Further update:
Rb25det NEO Stock Cams
Nitto Pistons and Rods. 9:1 CPR
HyperGear ATR45SS-1 Turbocharger
ID 1500cc injectors
Twin Walbro 525L fuel pump
Adaptronic Plugin ECU
Greedy Profect B EBC
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
Twin pulse manifold and twin 40mm
gate.
Car made 523rwkws @ 35psi, E85 fuel, With 250rwkws @ 4000RPM.
  • Like 2
Well done Tao, just proves again stock intake plenums work.
Time and time again, you see people throwing on expensive plenums coupled with near stock turbos lol.
#stockplenumworldrecord
  • Like 2
2 hours ago, hypergear said:
Further update:
ID 1500cc injectors
gate.
Excellent result. Just for the record is that with the stock throttle body?
Hey Tao, may I ask what your recommendation for my stock internal 1jz would be to replace my twin factory setup, I want to maintain the quickest response while being able to chase 300kw with minor headroom above That for say 350 as when I do some headwork soon I will put studs in it and up the boost a bit more. Have an emanage blue to be installed, and already have an FCD with profec b controller currently on a jzx90 mark 2.  Supporting mods there but need to work on the fuel system. Just trying to narrow down a specific model in the lineup
Hi, Recommended turbo is our ATR43SS-2 ball bearing model in T3 .63 Vband rear housing. it will be capable of making a super responsive 350rwkws.
Another result to share. R33 GTST running one of our ATR45SAT Ball bearing turbos externally gated on E85 fuel.  Stock standard Rb25det engine with head studs, and valve springs.  Car made 414rwkws @ 24psi tuned at Chequeredtuning Victoria.
  • Like 2
I asked this question a while ago about dyno sheets but with a tcf of 1 isn’t that engine power and with a tcf of 1.1 or higher wheel power?
i went through a low talk with a guy here in nz to get my 400kw sticker.
My tcf is set to 1.1 as I’m only 2wd and 1.2 for 4wd or am I only the wrong page or am I reading the wrong book
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
