The NZCAS worked nicely. Stock had fair bit of fluctuation up top.
Lexxi32: This version is one size up. The 537rwkws version on the GTT.  I think its using about 30kws driving the front diff, it would be sitting around 450rwkws ish on 28psi.
  • Like 1
Got my car tuned at the end of last year, I'm not sure if it's a good or bad result for so little boost.
Stock Rb25det w/ Z32 nistune, Hypergear Atr45sat, 1000cc injectors, blitz return-flow intercooler, splitfire coils, 255 Walbro pump directly wired, xforce 3" dump pipe & cat, apexi 3.5" exhaust, 3" metal intake to stock airbox.
Result was 230kw on 15psi dropping to 13psi.
Car was tuned with the 13psi wastegate spring.
Tuner couldn't figure the boost controller out proply and seemed hesitant to run the 18psi spring, he also reckons stock fuel lines are not really up to the task to run around 20psi.
And also noted the fuel pressure differential isolating, and suspected a fuel return issue from reg to tank, not sure if everyone gets this or I have an issue.
after x amount of time on the dyno I wasn't sticking around to play.
What do y'all think?
Edited by dyl33
Thats the usual amount of power seeing with supporting mods and boost given. Need a big FMIC, and possibly an exhaust cut out with a 20psi actuator to hold 20psi. and should see around 280rwkws mark.
What do the 2 fuel pressure lines represent? Is that a  before and after ?
Thanks for the reply @hyper-gear yeah I know the intercooler isn't desirable, but ive seen a guy up my way make 280kw with an r34 hiflow turbo on 18psi with the same blitz return intercooler only differance was a link ecu. So I'm thinking maybe I should put the 18psi actuator on and try again.
I'd like to avoid cutting a hole for a proper intercooler at the moment just to avoid any unwanted attention from the police, but it might be on the cards in the future.
Have you had any issues with stock fuel lines not being up to the task of running 20psi? because you run a lot of boost in your cars? Do you have stock fuel lines?
Im not to sure ben, I'm not that clued up on the ins and outs of fuel pressure and tuning.
He just said the fuel pressure differentials isolating and suspected a restriction between the reg and tank.
Was hoping it made some sense to you guys.
8 hours ago, Dose Pipe Sutututu said:
This won't make a difference in power.
Yeah it shouldn't, I reckon part of my result was due to him not being able to use the boost controller properly.
Do you still run factory fuel lines in your car?
Seeing as nissansilvia is dead, thought I would ask here..
ATR28G2 or ATR28SS1.5 for a standard sr20? Has poncams, 740cc injectors, exhaust, intercooler, nistune etc, currently using a t28 at around 260hp. Looking for 300+hp, and as responsive as possible as its mostly a street car. Thanks!
Not anymore since installing a surge tank, but before running 1.7bar of boost, a single 450Lph Walbro, I was doing 372kW at the tread.
However in saying that, I did have fuel return issues. Even with the FPR fully wound out, I would still get 2 bar of fuel pressure. Back then I wasn't running a fuel pressure sensor so can't tell you if there were issues with fuel pulsation - which I suspect was probable due to weird lean spots in my fuel map.
Now I use both lines (OEM feed and return) as only a return and fuel is fed to the rail via a 8AN.
ATR28G2 with a BB upgrade in T2 .64 internally gated would be something nice to make up to 350rwhp with excellent response.
On 22/02/2021 at 5:27 PM, hypergear said:
Thanks for the tip. Yes I though it might be the case, so I've added a cut out on the front pipe. Highly recommended for power hunting.
What’s the theory behind this? Why not put a real exhaust on it that isn’t restrictive/Japanese junk and not the noise?
There is no reason why a 3.5-4 inch exhaust can be reasonably quiet provided that you get quality mufflers!
Complexity for no reason apart from not sorting the setup out properly from the beginning!
This shouldn’t be “the thing to do”!
why create noise and unnecessary attention to already “on the radar car’s”? SHUT THEM UP!
  • Like 3
I agree with the Pig. Build it the right size with quality muffs and there shouldn't be an issue.
Something the pig didn't point out is the mess this shit leaves under your car. These things are starting to become quite valuable too so having it caked with exhaust soot and oily shit makes it a nightmare anytime you wanna work underneath the thing too.
This kinda thing devalues your car and is what draws the police's attention to our cars with this kinda rubbish and unnecessary noise.
Testing the cut out the GTT made 17kws on 421rwkws with no other mods.  I've had cars with 3.5 and 4 inches exhaust, its a struggle for room under the car fitting the right mufflers. The cut out doesn't open till 20psi, Car now is stockish quite on cruise and doesn't restrict performance.
  • 4 weeks later...
Some more time in prototyping, using the same set of housings but different wheel profile, I've managed to gain 250RPM RPM of better response while no lose in power, it is a pretty good out come consider no wheel size changes. I'll make custom housings next and see if that could improve response further.
Red is Current ATR45SS-1 and Blue is prototype.
  • Like 2
  • 1 month later...
Further development on the T4 printed turbo on Rb26. This prototype made a pretty big differences, peek 377awkws while making 20psi by 3500RPM and 220rwkws @ 4000RPM. Will doing few more things and hopefully seeing 420awkws+ without loosing response.
  • Like 4
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
