On 07/05/2021 at 10:50 AM, hypergear said:
Yep it was more responsive then the stock twins, and held boost all the way to red line.
T4 twin scroll or single? What AR and when we can buy it 💓
Its currently a single scroll T4. I'm making a new prototype for 400awkws with same response. Will be available for public in T3 or T4 rear housings once tested in about two weeks time.
Tested more more Protoype Rb26 T4 Turbo today.  Car made 443awkws E85 at 27psi, reaching 20psi and 200awkws by 4000RPM. Will be looking at Cam shaft upgrade and slight turbine trimming for the next run.
Edited by hypergear
  • Like 1
ATR45SS-1 Ball beairng Turbocharger in T3 Vband rear externally gated. In an R33 GTST, built Rb25det engine, factory stroke, with 264 camshaft maintain VCT. Final result was 472rwkws externally gated, power pulling all the way to 8000RPM on E60 fuel with 230rwkws @ 4000RPM. It would easily make 500rwkws+ with upgraded cooler and fuel system.
  • Like 1
  • 3 weeks later...
On 05/06/2021 at 9:35 PM, hypergear said:
Following the car above, now with E85, Pull 511rwkws and still plumbed back gate.
RB26 owner's wet dream. On song before 4500rpm and make those kind of numbers.
  • Like 2
On 08/06/2021 at 1:28 PM, SKYMAGGOT said:
What size is the exhaust?
3.5 inches to 3. there should be another 20 kws left in it once externally gated with a better cooler.
Result for you. ATR43ss2 ballbearing version compared to Garrett GTX 3076 gen 2. Same 0.82 externally gated housing used on both, and the turbo was the only change to the setup. Forged RB25, Supertech valvesprings, 256 Poncams, topmount steampipe ex.manifold with Turbosmart 38mm external gate, 3.5in intake pipe, 3.5in turbo back exhaust, Apexi PFC. P98 fuel.
Disregard the pink line; that was the GTX running an EBC that overboosted, run aborted. The blue line is the ATR43, no boost controller, just running wastegate pressure. The red and green lines are the GTX, also just running wastegate pressure....crappy ex.manifold resulted in spiking a much higher boost pressure, another story so disregard that aspect of the higher HP when it hits 24psi.
Important part to note is the ATR making more HP through the entire run right up until the boost creep on the GTX. Also to note, the R35 afm in a 3.5in pipe was hitting 5v at the peak of the red run.
Here's the run of just the ATR.
Just under 400rwhp. Note this was also with an inadequate boost controller; now running a Greddy MAP controller allowing for boost to come on stronger earlier without overshooting at higher rpms, so the midrange is now stronger.
Same dyno and tuner for both, just done at different sessions.
Edited by hardsteppa
  • Like 2
Similar to an ATR43SS-2
Another ATR45SS-2 result to share, This time in a T3 1.0 Rear with a Built RB26 running stock cams. Car made a impressive 625rwkws @ 38psi E85 fuel.
New prototype ATR45SS turbocharger. Now sitting at 485Awkws @ 32psi of boost, all in by 4200RPM. New turbo made 40kws more in power while no lose in response. Car's nice and and responsive to drive. Currently sitting at the limitation of the stock engine, considering of doing a forged build soon.
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Apexi FMIC
Trust 3 inches turbo back exhaust
PS2000
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS Prototype T4 Vband rear
3 inches front pipe with cutout
Final result so far 485awkw / 650awhp @ 32psi E85 fuel. All in by 4200RPM.
Great work Tao, looks like Trent ramp in the boost gently to limit torque so the stock motor wouldn't explode. Judging by the graphs you could get more boost in earlier but most likely break the motor LOL
That comp cover also looks great, much nicer than premium products with poor casting and material missing.
  • Like 1
On 06/05/2021 at 9:01 AM, hypergear said:
Further development on the T4 printed turbo on Rb26. This prototype made a pretty big differences, peek 377awkws while making 20psi by 3500RPM and 220rwkws @ 4000RPM. Will doing few more things and hopefully seeing 420awkws+ without loosing response.
Is that turbo already available to buy?
  • 3 weeks later...
Some footage from last Winton practice from Mr Oversteering, Still running one of our high flowed OP6 Turbocharger making a responsive 310rwkws.
  • Like 1
  • 5 weeks later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
