Probs a stupid question.....
But what is the price differance between a Garrett 3076R to buy and the equivilant Hypergear item say SLSS2 or SS2 which seems about the same response and kws etc??
Read back through previous pages and look at the dyno printouts. Hell, even better would be to look at the RB25 Turbo Upgrade thread.
Don't mean to sound rude, but seriously it's not fking hard.
I would go a Hypergear over my old 3076 the power delivery of the 3076 on 98 was way to linear but taos magic slss2 was so much more fun to drive with its aggressive delivery didn't notice any difference in lag and that's both on a rb25 with stock manifold internal gate and a return flow cooler obviously with other support mods
Hypergear ftw
Thanks for the feedbacks.
Here's a set of GTR high flows that Ive done recently. Using ATR28G1 chra, which is in 60mm comp and 56mm turbine
Also there is a update on all R33 and R34 turbocharger high flow profiles. I'll be going up in one size up from the standard high flow. should increase power by about 10%.
Also ATR43SS3 VNT turbocharger is built. This time the lever is working 100% with the actuator it can be activated with about 5 psi of boost under load. I should've taken a photo before installation, but I guess I'm too keen to trail it on road. Feels pretty responsive, hopefully be hitting close to 400rwkws with full boost around 3500rpms.
Is there are actually a break down page showing all the HG varients? The names make absolutely no sense in regards to power or features - that I can tell, and there isn't a place I have found which allows someone to look at and get an indicator of whether something is ball bearing, journal bearing, billet, cast, bolton or universal etc etc... just random names that someone has to follow this thread daily to understand. SLSS2 vs SS2, etc - PU? FNT? what does it mean?
Maybe the first post in the thread could be updated as the varients change so one can go back there and see what is currently on offer? Apologies if there is something like that somewhere I haven't looked, but amongst other things I'd be much more likely to recommend HG turbos to people if I could make sense of the naming and specs - I don't really have the time to follow all the posts as new names and new specs roll out.
Cheers
They are coded in pretty simple terms, I guess I should have made it more transparent.
ATR: Just a name standing for "Advanced turbo research"
followed by: "Turbine pattern" "Type of comp wheel" "HP rating" "Turbine type" "Bearing type"
"25": .64 and smaller T2x turbine housings
"28": T2x SR20det turbine ended turbochargers
"43": T3x universal turbine ended turbochargers
"G" Cast compressor wheels:
G1: 320HP
G2: 450HP
G3: 500HP
G4: 600HP
"SS" Billet compressor wheels:
SS1: 350HP
SS1.5: 400HP
SS1PU: 470HP
SS2: 500HP
SS3: 550HP
SS4: 630HP
Like the SS2.5 high flow: SS2 500HP compressor working with a Larger then usual (G4) turbine wheel made to extract power from tinny turbine housings like the 21Us.
"": Usually they are built in journal bearings
"BB": Steel Roller bearing
"CBB": Ceramic roller bearing
FNTA: Fixed turbine nozzle with wide opening angle (More power, less response)
FNTB: Fixed turbine nozzle with narrow opening angle (Better response, less power)
VNT: moving turbine nozzles.
Eg:
ATR43SS3BB.82VNT
T3x based turbocharger
Billet wheeled compressor in 550HP range
Steel roller bearing
.82 turbine housing
Moving turbine nozzles.
And
ATR43G3 .82b
Cast compressor wheeled in 500HP range
Journal bearing
.82 turbine housing with narrow opening angle
High flow codes:
Standard basic high flow.
"PU": Powered up. including larger .82B turbine housing and stronger actuator
"SS": Billet compressor wheeled high flow profile.
Eg:
R33 PU high flow. Means a customized 500HP high flow that has an .82 type B turbine housing with a stronger actuator.
Recently introduced turbochargers: ATRSLxxx
SL: L2 turbine ended turbochargers followed by volume size: 8cm, 10cm, 12cm
20.5 / 25.5G: Redeveloped billet compressors based on the original wheel
SLSS2: L2 turbine ended turbocharger using SS2 compressor front end.
FNT, VNT, CBB and BB extensions can also be added to ATR"SL" category if they've been built that way.
G1: 320HP
G2: 450HP
G3: 500HP
G4: 600HP
SS1: 350HP
SS1.5: 400HP
SS1PU: 470HP
SS2: 500HP
SS3: 550HP
SS4: 630HP
Eg:
ATR43SS3BB.82VNT
.82 turbine housing
And
ATR43G3 .82b
Journal bearing
High flow codes:
Eg:
Awesome, thanks for the response - that makes things a lot clearer and probably handy to have around.
I could see that being rearranged into a tabular form. Frame types down the left side, features (FNTA, FNTB, BB etc) across the top. Power expectations and response information contained in the various intersections in the table where turbos exist (because there will no doubt be some empty cells). You could colour code it so that external gate expectations were different from internal gate, etc etc.
That looks awfully familiar especially with the two studs, I dont suppose it is mine? :whistling:
Got mine on Monday which was good, just need to bolt it all back together now.
i have to admit, i like your turbos..but the naming drives me crazy and doesn;t make much sense unless you look at this thread
It makes it very hard to sell as a product
cheers
darren
I agree. I don't run one of your turbo's, but judging by the feedback on here I know you are putting out some great products with fantastic service to match, not to mention you are obviously putting a lot of R&D into your products. I do think however it would be worth considering coming up with naming convention that is broken up into distinct series and generations to make it clearer what your are offering. I have always been a bit confused :P Maybe its just me!
I think part of the issue is the constant development in his forever improving line of turbos.
But I do agree.. a simple size based model code would make things a lot easier, with one to two character designation for identifying variants.
ie 6074-SS for the SS2, and 6076-G3 for a ATR43-G3.
That way sizes are known by the model code and we can tell if the the turbo is a cast or billet item. An advance in technology should just supersede the older model.
Just my view point.
Some SS3 VNT update. The system worked perfectly and I was been able to control nozzle movement through an ordinary boost controller.
It made 394rwkws on 23psi of boost so far
I must address this result was archived by a large size turbocharger using stock cams and stock cam gears and boost. It is not enhanced through larger cams or cam gears.
ss3boost.jpgAs shown, the boost behavior in reference to degrees of freedom given by the actuator controlling the VNT nozzles. The whole boost curve shifts to the left as the nozzles stayed in the deactivation position for longer. How ever by doing so it also made the exhaust gas temperature very hot.
As we were adjusting the boost controller for dyno runs the car experienced some ignition problems so we had to call it a day. It will go back for any other run once I have it rectified.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
