  • Replies 219
Aiming to get back to the dyno the weekend (or Friday) after the easter long weekend.
Guilt, will you be free sometime around then?
I want to wind the boost up from 17PSi to 19PSi also. Hopefully then with a bit more boost and the hi flow cat, it will crank out ~300AWKW.
It will be interesting to get a power run done on a Sydney Dyno down the track to compare results.
How did the dyno run go Bakes?
Due to Paul having to go to Qld for work I took the car to Sydney to get it final tuned. Car got tuned today by Scott at Insight Motorsports. Ive spoken to him over the phone, it made 396 Horsepower (295Kw) at all 4 wheels at 1.3 Bar.
This is with my 19 inch Volks on also so with stock wheels it will pull 310-315 All wheel Kw. Im looking forward to driving the mofo.
Ill post up graphs when I get them.
Why would it make more power at the wheels with the 18's ?
of all people i thought you would know this dude... unless you use a hub dyno.. the size of the wheels and friction properties of the tyres will affect the power output on any particular dyno.. high reading or low reading.. his volks have a rolling diameter of 675mm while the original gtr wheels are 654mm, so the original wheels will give a higher speed reading and slightly higher power reading. the big wheels will give a higher torque reading and less speed.. it doesnt matter anyway as the dyno was just used to tune it.. scott @ insight said it has got more to offer and its a very safe tune for day to day driving.. and its been tuned for maximum low down response... not top top end power.
regardless of power readings and dynos and crap thats gone on and what anyone thinks.. this car now hauls. it has fantastic driveablity, excellent fuel economy, and power to boot.. for the amount of punting bakes does.. the money has been spent, the parts are fitted, and the result at the end are what matters, it should keep him happy for a while..
simon, if your not content with anything about bakes gtr, feel free to line your r31 up anytime you like (or your mates mp3 player) .. until then.. let him enjoy his car stop worrying about what you could have done for him..
Car made 400HP at 4 wheels but was pulled back a bit on final tune to keep everything nice and safe (stock motor) Not running crazy boost either. (only ~1.2/1.3 Bar)
The tune is fantastic, runs so smooth. Tuned for cold start also, Im very happy with it. Ive found no need to give it more than 70% throttle yet either, she goes pretty good ;)
Here is my performance mod list:
* HKS Front pipe, HKS rear pipe with Hi Power Muffler, Hi flow cat
* Garrett 2860R-5 Turbos
* HKS SPL full piping kit with HKS super power flow pods
* Nismo Fuel Pump
* Turbosmart fuel regulator with pressure gauge
* Hypertune Billet fuel rail
* Siemens 610cc Injectors
* OS Giken Cam gears
* Nismo twin plate clutch
* Vipec V44 ECU
* Tech Edge Wideband AFR controller
* HKS EVC6
Tune results at different boost settings on Insight Motorsports Dyno, ALL WHEEL HORSEPOWER: (19 inch volks on)
Now for those interested I had some fun with excel to compare my results from where my car was stock except for exhaust to where the car is now:
Notes: Above dyno graph is in All Wheel Hosepower, the graph below I made is in All Wheel Kw
: Blue line was done on IS Motor Racing Dyno with stock wheels/tyres
: Yellow and red lines are on Insight Motorsports Dyno with 19 inch wheels
My biggest loss in response is ~ the 100Kw mark with a loss of ~550/600 RPM. The -5s catch up ~ the 4400 RPM mark
Would be interesting to do another power run now on the IS Motor Racing Dyno.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
