They are on rowdy gtr's old car on here or his current one..? i think he said his were 18x10 when i was picking his brain about them.. did you get all adjustable arms? should be able to fix the offset a little with them.
Looking good otherwise Andrew :P i think you've sparked some inspiration in me finally.
if the weather is fine this weekend i'm getting stuck in.
  • Replies 615
Posted Images
Suspension and brakes are all stock at the moment... I'm leaving the two most important parts of the car until last.
.... and yes, I'm counting on the 3-4 degrees neg camber to fix the offset issue at the front... I hope that guard rolling will be sufficient to take care of the rear.
I'm not worried anyway... If I need to get the guards panel beaten to make them fit, so be it. dunno.gif:P
Check out the g-sensor that I bought... Don't ask how much this was. My sphincter is still puckered after handing over my credit card :)
If you dont mind me asking, how much d!ck does nissan stick in your butt for one of them??
i think i was in need for one after i decided to pull one apart to see how it worked.. tho i do have 2 more at home i think.. but are also used..
looking sweet merlin. good thing you were on top of the pipes. all the cheap chinese coolers and piping kits, and dump pipes for that matter were all shocking on the inside. overhang where welded, dags, swarf etc a-plenty. the japanese stuff is clean enough on the inside to lick if you so desire... and sometimes you do... :P
so when is my invite to come over and help...
Retail pricing was $2300.00...
You should be able to get it for under $2000.
Good to see your making some progress mate all is looking good to. Looks like it wont be to far away from getting sorted. You caught up with me pretty quick.
No way... I'm still on my interim engine. I still need to sort out the proper powerhouse :)
Suspension and Brakes are being sorted as we speak, so it shouldn't be too long before I can give it a shakedown and start tuning the setup...
Andrew,,,the chassis rails look dirty. I'm shattered.
................. I'm ashamed to say that I have actually cleaned up those chassis rails with turps and metho :):(:)
Motherf**ker!!!!
Can you afford good suspension and brakes anymore??? :/
What are you using suspension wise considering it a track car?
Rhys
Hey Andrew,
Did i read you have it started?? with the Amuse exhaust on?? please tell me how it sounds!! or record it for me?? i am dying to know how the thing sounds. it just collects a bit of dust and makes no noise at home for me..
Yeah sure is mate...
It's running on a very rough old tune on a dodgy Power FC, but it's running :)
Very deep, loud, throaty growl to it... I love it, but there's no way you could drive it on a daily basis. It's 100% cop-bait.
I tried to take a video of it for you, but I realised that my stupid Sony T200 point and shoot camera can't take any video!!!! WTF :thumbsup:
Any weight target overall of the GTR planned once the project is completed?
There's a LOT of tuning of suspension and getting used to the car before I start chasing the SERIOUS weight reduction stuff...
But after I "speed hole" all the non-structural metal panels, carbon doors, carbon boot, lexan windows, cut out the boot floor, etc etc, I'll be very happy to get it down to 1300kgs.
The last ($$expensive$$) push for weight target is a while off yet though.
Need more big signings at work to pay for my road car, mortgage, holidays, booze, drugs, etc, and way down the bottom, lowest priority is this silly fun car :D
Motherf**ker!!!!
Can you afford good suspension and brakes anymore??? :D
Rhys
Everything adds up (very quickly) :sick:
If anyone is keeping track of the cost of the parts that have been put on this car, don't tell me... I DON'T want to know :(:blush:
My brake setup (on order):
FRONT:
AP Racing CP5555 6-Pot Calipers
AP Racing J-Hook 355mm discs
Ferrodo DS3000 Pads
BF Goodrich braided lines
REAR:
AP Racing CP7600 4-Pot Calipers
AP Racing J-Hook 343mm discs
Ferrodo DS2500 Pads
Hydraulic Handbrake
Tilton Lever Brake Bias Adjuster
Yes, I know that it will be massively rear biased, but I'll see how I go. Might give me a reason to put in a pedal box and balance bar ;)
My suspension will be (on order):
DMS 50mm giant strut coilovers
Competition valving
6xxlbs front springs
4xxlbs rear springs
Still pulling the linkages together, but so far, I have:
Cusco front upper arms
Cusco rear upper arms
Cusco tension rods/radius arms
Haven't decided on swaybars yet... Probably just go for adjustable Whiteline ones to start with and see how they go.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
