  • 3 weeks later...
So you're saying you're left with a car with an absolute max weight of 1,400KG...
Not a lot of wiggle room if you need to carry tyres, fuel, or much else.
Plus it has a max tow ball weight of 100KG... So at max trailer weight you don't get near the 10% towball weight... That'll make that trailer so nice and easy to tow... Not...
Plus a kerb weight of 1716KG, add your 100KG tow ball weight on and you've only got 400KG of in car weight you can carry before you're over your GVM... So put two adults in at say 80KG each, you now have 240KG of in cabin weight you can add... Not a lot of room weight wise for tool boxes, fluids, the tyres and fuel that really can't go in the trailer as it'll end up over weight soon...
Personally I'd stick to something with better specs.
Balls :)
All I'm suggesting indirectly is that for some people a current mid size SUV might do the job for them. I find that the Cherokee, not a Grand Cherokee, tows like a champ. Much more stable and comfortable than the Triton based diesel Challenger I used to have and which was rated at around 3,000kg towing capacity.
Yes, CTV would not be my choice for towing but given the tow rating I guess it would handle it.
Basically though there are medium sized SUV's out there that tow very well. My 2015 Cherokee has a Sport mode for the auto which engages all wheel drive and stability control on the fly. In my experience it's a nicer tow car than a lot of the old school 4WD's out there.
  • 6 months later...
  • 4 months later...
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
