yeah engine looks a bit crowded, the result of putting that huge filter in is staggering. I've seen a few posts on other forums in the US complaining that the vh45 power band flat lines above 5000 rpm. I had the same issue, a massive decline in the rate of acceleration. apparently a 12in long 6in round filter does the trick. who would of thought. now we just have put an air box around it.................some how.
on another note, Sean said me he talked to the BMC filter guy at the stand at super-lap on Saturday, and told him his filters suck :spank:. I wonder how that went down. they said the biggest enclosed air filter they make only has a 100mm insert.
I put it nicely to them that it was restricting the engine, as this 4.5L with the factory 90mm intake @7000RPM would be ingesting 'x'litres of air! The BMC filter canister unit that we originally fitted had an 80mm intake, and enough filter cross section for an engine half the size...
So that's why it was flat-lining after 5000RPM, not enough airflow at the higher RPM's. The 80mm intake was my first guess why it was a restriction. So much better now, it sounds completely different, with so much filter area available now.
As said before they do have a 100mm intake adapter that is meant for a honda S2000, but the filter element itself would still be a restriction. Could run 2 filters, but there isn't enough room, and cost is up there.
turns out that Ross tuffbond balancer i got made is a $900 paper weight. its not even close. the standard balancers have 3 pulleys i needed the second pulley only as i only run a water pump and alternator of the same pulley. they made it with the first pulley and then it's the width of the second, so nothing lines up. not happy again, why is good help too hard to find! it probably even won't bolt on, 7 months for a balancer that they just winged. :rant: really angry!!!
turns out I'm an idiot, the balancer was made to sit spaced out from the engine block. so it does line up there just will be an air cap of an inch between the engine and the start of the balancer. crisis over.
the 450sx now has a digital climate control from a type x, we needed to rewire the 3 plugs for the analog one in to 2 plugs for the digital one. that and it's running close to 19 degrees of timing now, it was running 17 degrees factory... seems a little hi but apparently the factory setting are 15 +/- 2 so 17degrees is the limit so it works. the question is should i put cams in it?
Josh, at the end of the day... was the vh45 swap worth it??
hell yeah, i was just going to put a rb26 in it when the ca original went but really wanted something different. but after it's all been said and done. I'm really glad i did this conversion, i really can't get enough of how this car drives now, the chassis has come alive. unlike the turbo it's all up to my right foot and i love that.
this. :thumbsup:
very nice work mate.. it does have a tough corvette muscle look to it imo.
i'd love to see this thing in action, forgive me i did skim through the thread.. any vids??
listen out for Steve's comment at the end
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
