The booster does create alot of resistance when there is no vacume. I was surprised when i pulled it appart, how tight all the moving parts were.
I don't see much point in doing it to a road car.
I never had much luck doing the double flares myself ben, how did u go with them? I ended up just taking them down to tas brakes to get done.
Its coming along well though, looking forward to seeing it on the road!
they came up well, i found the key was to tighten the buggery out of the pipe holder, otherwise the pipe slips when you do the first part of the flare.
what about a track car with numberplates though?? worth doing then??
got a parcel from roy yesterday.
abs unit has been tested and (now) doesn't leak, as it uses bubble flares instead on double flares.
have to brace the buggery out of the brake pedal now, as it's pretty flexy.
I think damo should give up his day job as an auto leccy and become a seamstress. I could see him on the sewing machine punching out overpriced designer dash's.
Good job guys!
id prefer to quit and go into full time race car building. but ill have a go at that to
I haven't really detected any difference between the GTST and GTR stock ABS. neither are super fast but thankfully they are quite lazy (ie quite a high threshold) so on the circuit you will almost never have it cut in at all. on uneven or broken surfaces though (which I'm sure you get plenty of in tarmac rally) they are shithouse. can't cope well at all with low grip tarmac and then you find the sampling rate/pulse speed etc become a problem. for tarmac rally I can see for sure a better unit is a good idea. I'm not sure how much is in the valve body or how much is in the programming and processor power of the ECU. I suspect most of the gain comes in smarter/faster ECUs.
Can I ask a stupid question at this stage?
I have upgraded my brakes to the Brembo size (F40, Brembo rears & larger master cylinder).
The ABS on the R32 was originally pretty ordinary. With the larger brakes it is even worse. Does the povvo pack ABS unit have enough capacity to release the large pistons on the Brembo callipers or do you need a different unit?
I suppose the question is: Is an R32 V-spec ABS unit different to the poverty pack GTR version?
A second dumb question relates to the Vspec ATTESSA unit rate. Can you sling in a later unit from a 33 ie up from 4Hz to 100Hz & does this affect the ABS???
Sorry for the thread hijack.
The pump unit in the 32 series is the same.
My GTR has Porsche 6 pot's on it, and i can still flat spot tyres with it.
I'd put a fair but of thought into a Tarmak Rally GTR, and if wanted to build the best 32, you'd fill it with R33 bits. The ATTESSA PRO ecu is day and night compared to the R32, heaps faster, ABS is heaps more responsive (but not too aggresive) , also feeds torque to the front wheels under brakes (found that from datalogging it) for stability, and a R33 transfer case to handle the higher baseline awd. IMO the biggest problem with the 32 is the old tech ECU's, it was bloody advanced in 1989, but tech came a long way by 1995, i think the pumps are fine, just the ECU that drives them.
A R33 ATTESSA ECU would be well worth doing, as you have better ABS, and AWD. I'm not sure how hard it is to disable to A-LSD in the ATTESSA PRO, cause that's the one you want. Only thing you'd want to consder is if the R32 tranfercase can handle running a little all the time.
On another note, where did you get the rotors for your F40's? Are they 2 peice, and 332mm?
Edited by sav man
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
