seems pretty laggy, but I guess it doesnt really matter for a circuit only car
really? I wouldn't call it laggy. it reaches 260kw at 5,500rpm and holds it to redline. that's a pretty nice bit of power for a little 2L.
It's coming on hard from 4,500 onwards and is very strong by 5,000. so as long as you can keep it above 4,500rpm it will be hauling ass!
  • 3 weeks later...
Well after Targa I think it's time to get a gated sump after i ran a bearing the night before the event. I'm also going to rethink the breather setup to stop it blowing oil out of the breathers all the time, and last of all put some cam gears on to improve response.
I gained some motivation today, put the dead engine on the engine stand, and drained the oil out. There more than an acceptible amount of bearing on my magnetec sump plug. But I ran out of motivation when it got time to remove the sump.
Some incar from targa
Riana:
Cethana:
Nice vids...seems E85 is the way to go :)
I call 1bar @ more than 5000rpm laggy, but thats just me :)
and yeah doesnt make a difference on the circuit as long as its kept over that sweet spot!
Cant have everything in this world, and you dont make 260+rwkws from an RB20 unless you move the power band up over 4,5000rpm!
You so can have everything... You just need to shoe horn a V8 in with twin turbos... :D
So what were you doing the night before the event to spin a bearing and call oil surge issues?
Was at Baskerville raceway. I've now been over the datalogs, and the oil pressure keeps dropping to 0psi under brakes (didn't for targa though)
The lag wouldn't have been a problem if I was able to rev to 8000rpm, but the new engine had issues to prevent that, so I lost 1000rpm off the powerband.
Edited by sav man
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
