Spotted yesterday at about 6ish on the m4, awesome black stagea with plates sta634, good stance and about 100m up from that was nur spec blue 34gtr getting onto the m7.
If that Stagea was a NM35, it was probably Craig aka "Debarkle." Post it in the Stagea spotted section, and you'll know for sure: http://www.skylinesaustralia.com/forums/topic/53437-spot-the-stagea/
"Aurora Flare Blue" R35 GTR with plates 'GTR35' on M4 today. Hnngg. They look so good in that colour!
Also a orange 33 gtst was parked on the shoulder on M4 underneath the Cumberland Hwy overpass. Hope he didnt have any car issues...
Im not familiar with the Stagea models, it was one of the RB powered shaped Stageas not the VQ powered ones.
Ahh okay.
RB-power = C34 chassis
VQ-power = M35 chassis. :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
