Two R34s parked together at the Caltex/McDonalds/Red Rooster/KFC on the Cumberland Highway (Briens Road) in Northmead this arvo around 4.30pm. One was yellow with some body kit, the other was white and I couldn't see the whole car so no idea if it was standard or not (they were a bit too far away for my eyesight to capture properly).
Sounds like Georgia and Paden
White 34 super cheap villawood car park around 12 pm with sau sticker driver side
Probably me or Ricky (xntrq) :P i was around there at that time but didnt park cos it looked packed haha supercheap boxing day sale
me ;)
Super cheap was pretty packed waited around for 5 mins hoping owner to come out to say hello but left
:action-smiley-069:
I was in there with a mate and he was reaping the boxing day sales.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
