Yellow-Jackets-Promo-Cards--Concept%20co
We are proud to offer Skylines Australia the worlds best priced performance coil packs.
With thousands of sets sold worldwide, these are proving to be very popular and have been on the market for around 8 years now with some very impressive results.
Here is what one of our happy customers had to say about them:
I've been running these Yellow Jackets now for 3 months in my R33 GTR. Still no problem with spark blowout as I previously did with the old coils, and still plenty of power!
Done 2 HARD track days with no problems at all. Even added extra timing. Now at 28deg at 8000rpm WOT! Over 320+kw now!
I have now bought a second set of Yellow Jackets for a mates R32 GTR which had a constantly changing misfire, even after gapping the plugs to 7mm and replacing them. He wanted to upgrade the turbo's for higher boost, so I said he would have to change the coilpacks. He was dubious that this would fix ALL his problems, so the turbo's were fitted. No improvement of the misfire after installing the turbos, running them in and resetting the ECU. So I fitted the coils, gapped the plugs to 1.1, and reset the ECU. He didn't believe me that this was going to work, but low and behold, smooth idle, acceleration, and cruise!
He couldn't believe the difference in the 'seat of your pants' feel in acceleration (stock boost).
Going to do a dyno run soon to see what the difference at stock boost is compared to original figures. Then a re-tune and add a boost controller.
Bang for buck, these Yellow Jackets cant be beat!
Unfortunately, out doing a "road test" in the R33 GTR, with the street tires, and now with bucket loads of extra torque, managed to break second gear. Same sort of use/abuse with the old coils packs couldn't produce the same 4 wheel power slides, just under heavy acceleration!
Luckily I had a spare gearbox, so I could make it to the track days.
BENEFITS:
- Increase in torque.
- No spark blowout at higher boost.
- Improved throttle response and smoothness.
- Increased Ignition Performance.
- Improved Combustion.
- Direct Fit.
- 2 Year Warranty.
- Solid Construction.
- Cost effective.
SATISFACTION GAURANTEED
Manufactured with Components from GE (USA), BASF (Germany) and Epoxy Resins from Switzerland.
EXCLUSIVE ONLY TO PERFORMANCE-WISE
YELLOW JACKETS COIL PACKS PRODUCT RANGE:
YELLOW JACKETS COIL PACK SET - YJ-RB202526-S1 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6.
- DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN RB MODELS:
SKYLINE R32 GTS-YHR31/HCR32/HR32-RB20DE (1989>94)
SKYLINE R32 GTST/4-HCR32/HNR32-RB20DET (1989>94)
SKYLINE R32 GTS25-ECR32/ER32-RB25DE (1991>93)
SKYLINE R33 GTS Series 1-ENR33/ER33-RB25DE (1993>95)
SKYLINE R33 GTSTSeries 1-ECR33/ER33 RB25DET (1993>95)
SKYLINE R32 GTR-BNR32-RB26DETT (1989>94)
SKYLINE R33 GTR-BCNR33-RB26DETT (1995>98.)
STAGEA WGNC34 (AUTECH)-RB26DETT (1997)
CEFIRO A31/CA31-RB20DE (1990>92)
CEFIRO A31/CA31-RB20DET (1990>92)
CEFIRO LA31-RB20DE (1990>94)
CEFIRO LA31-RB20DET (1990>94)
CEFIRO LCA31/LNA31/NA31-RB20DET (1990>94)
CEFIRO EA31/ECA31-RB25DE (1992>94)
LAUREL HC33/HCC33-RB20DE (1991>93)
LAUREL HC33/HCC33-RB20DET (1991>93)
LAUREL HC34-RB20DE (1993>94)
LAUREL EC33/ECC33-RB25DE (1991>93)
LAUREL GC34-RB25DE (1993>94)
LAUREL GC34-RB25DET (1994)
LAUREL GCC34-RB25DE (1993>94)
LAUREL GCC34-RB25DET (1994>)
YELLOW JACKETS COIL PACK SET - YJ-RB2526-S2 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
SKYLINE R33 GTS Series 2-ENR33/ER33-RB25DE (1995>98 )
SKYLINE R33 GTST Series 2-ECR33/ER33-RB25DET (1995>98 )
SKYLINE R34 GTR-BNR34 - RB26DETT (1999+)
STAGEA WGC34 (2WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DET (1996>98 )
CEDRIC/GROLIA ENY33-RB25DET (1997>99)
LAUREL GC34-RB25DE (1994>97)
LAUREL GC34-RB25DET (1994>97)
LAUREL GNC34-RB25DE (1994>97)
LAUREL GCC34-RB25DET (1994>97)
LEOPARD JENY33-RB25DET (1997)
YELLOW JACKETS COIL PACK SET - YJ-RB2025-N - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- DIRECT REPLACEMENT FOR THE FOLLOWING RB NEO MODELS:
SKYLINE R34 GT ER34/ENR34 - RB25DE NEO (1998+)
SKYLINE R34 GTT ER34 - RB25DET NEO (1998+)
STAGEA WHC34 - RB20DE NEO (1997-1998)
STAGEA WGC34 (2WD) - RB25DE NEO (1997+)
STAGEA WGC34 (2WD) - RB25DET NEO (1998+)
STAGEA WGNC34 (4WD) - RB25DE NEO (1997+)
STAGEA WGNC34 (4WD) - RB25DET NEO (1998+)
CEDRIC/GROLIA ENY34 - RB25DET NEO (1999+)
LAUREL HC35 - RB20DE NEO (1997-1998)
LAUREL GC35/GNC35 - RB25DE NEO (1997+)
LAUREL GC35/GCC35 - RB25DET NEO (1997+)
YELLOW JACKETS COIL PACK SET - YJ-RB20313233 - AU$420.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6. (NO HARNESS ADAPTORS REQUIRED).
- DIRECT REPLACEMENT FOR THE FOLLOWING RB20 MODELS:
SKYLINE HR31-RB20DE (1985>89)
SKYLINE HR31-RB20DET (1985>89)
SKYLINE YHR31/HCR32/HR32-RB20DE (1985>89)
CEFIRO A31/CA31-RB20DE (1988>90)
CEFIRO A31 CA31-RB20DET (1998>90)
FAIRLADY Z PZ31/PGZ31-RB20DET (1985>89)
LAUREL HC32-RB20DET (1986>91)
LAUREL HC33/HCC33-RB20DE (1988>91)
LAUREL HC33/HCC33-RB20DET (1988>91)
YELLOW JACKETS COIL PACK SET - YJ-SR20-S1 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4.
- DIRECT REPLACEMENT FOR THE FOLLOWING SR20 MODELS:
SILVIA/200SX - PS13/KPS13 - SR20DET - (1991-1993)
SILVIA/200SX - S14/CS14 - SR20DET - (1993-1999)
180SX - RPS13/KRPS13 - SR20DET - (1991+)
YELLOW JACKETS COIL PACK SET - YJ-SR20-S2 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
SILVIA - S15 - SR20DET - 1999-2002
X-TRAIL GT(Jap Spec) - SR20VET - 2002-2007
YELLOW JACKETS COIL PACK SET - YJ-CA18 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4. (NO HARNESS ADAPTORS REQUIRED)
- DIRECT REPLACEMENT FOR THE FOLLOWING CA18 MODELS:
BLUEBIRD U13-CA18DE
BLUEBIRD U13-CA18DET
EXA N13-CA18DE (1987>91)
EXA N13-CA18DET (1987>91)
SILVIA S13/KS13-CA18DE (1988>91)
SILVIA S13/KS13-CA18DET (1988>91)
180SX RS13/KRS13-CA18DET (1989>91)
YELLOW JACKETS COIL PACK SET - YJ-VQ35-S1 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN MODELS:
SKYLINE PV35/CPV35 (03-06)
SKYLINE V35 250GT/300GT VQ25DD/VQ30DD
SKYLINE V36 SEDAN (up to 2009)
SKYLINE ©PV35 350GT (VQ35DE, 06/2001 - 09/2007)
STAGEA NM35 250T / AR-X FOUR (VQ25DET, 10/2001 - 08/2004)
STAGEA : PM35/PNM35 (01-07)
INFINITI FX35 (03-08)
INFINITI G35 COUPE/SEDAN (03-07)
INFINITI M35 (06-08)
M35 VQ25DET (06-07)
FAIRLADY Z / 350Z Z33/HZ33 (Includes roadster) - (03-06)
350Z Z33 Touring Series 1 (VQ35DE, 12/2002 - 01/2007)
350Z Z33 Track, Series 1 (VQ35DE, 12/2002 - 01/2007)
FUGA : PY50/PNY50/Y50
CEFIRO A33 (99-02)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
MAXIMA (02-08)
YELLOW JACKETS COIL PACK SET - YJ-VQ36-S2 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- FACTORY RUBBER BOOTS AND INTERNAL SPRINGS REQUIRED.
VQ35HR & VQ35DE 3.5L V6 / VQ37VHR 3.7L V6 / VR38DETT 3.8L V6 :
R35 GTR VR38DETT (08-12)
SKYLINE PV36/V36/NV36
SKYLINE V36 sedans PV36/KV36 (06-08)INFINITI G35 COUPE/SEDAN (03-07)
INFINITI EX35 (08-Up)
INFINITI G37
TEANA PJ32/J32
MURANO PZ51/PNZ51
FAIRLADY Z Z33/HZ33 350Z (Includes Roadster) - (07-08)
Z34 (370Z) VQ37VHRFUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
ALTIMA SEDAN (07-12)
ALTIMA COUPE (08-12)
MAXIMA (09-Up)
MURANO (09-Up).
V36 VQ37VHR (2008-Up)
YELLOW JACKETS COIL PACK SET - YJ-VG30-S1 - AU$450.00 delivered within 2-3 business days - Addtocart.gif
- DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN MODELS:
VQ Fairlady Z (300ZX) Z32/GZ32/GCZ32 - VG30DE & VG30DETT
Front print - Plain back.
100% pre-shrunk cotton.
Available in White or Grey only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
- The link next to each item will take you to our site where you can view pics & details and where you can purchase & pay via Paypal with our secure online checkout system.
We also take direct deposit, bank check or postal money order. Please PM me for details.
Please PM or contact us if you have any questions regarding these items.
Cheers,
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
  • Replies 217
Hey mate, saw you're advert just in time ... I had added spitfires into my cart lol. Can you please check my PM? messaging you now ...
PM replied, thanks very much for your purchase :D
Please PM me when ER34 Neo version becomes available!
Cheers
Will do. Im currently looking for someone to test these for me in an R34 GTT thats used as a daily driver and occasioanlly visits the track.
See HERE for more info.
:D
Hey can you pm me when you release these aswell? have you ran them on stock 34 neos yet?
No probs, I will be sure to let you know.
Weve ran them on a couple of GTTs and GTs both with mild mods so they should be fine on a stock setup.
Im still chasing another tester for these so we can get more varied results.
  • 3 weeks later...
R34 GTT/S2 Stagea RB25DE(T) Neo Yellow Jackets coil packs will be in stock and ready to ship from today (04/01/10). :)
Price is $410 delivered Aus wide.
  • 2 months later...
Hi there, wanting to purchase a set of these for a SKYLINE R33 GTST Series 2 - ER33-RB25DET (1997).
Just want to confirm that you have some in stock, and ask how they're shipped (courier or auspost e-parcel) please?
Thanks,
wil..
Thanks,
wil..
Hey Wil,
I have plenty of stock of all types and I send them via Aus Post (Express Post - 2 business days to Sydney and within NSW).
Cheers,
Paul.
:blink:
Thanks Paul, will order asap. Tried twice just then, but paypal seems to be doing some sort of maintenance and keeps crashing out on me just before I get to confirm payment. There's no record of payment in the system so, hopefully I'm not out $780!
Will try again after 2pm Sydney time (which is the end of paypal's scheduled maintenance..).
I just did a "mock" purchase from my sire using paypal and it seems to be up and running.
Let me know if you have any more issues and I will arrange to send you an invoice via paypal.
Cheers.
Cheers.
Just ordered and paid for via paypal :D
Thanks Paul!
Just ordered and paid for via paypal :P
Thanks Paul!
Thanks very much. I will send them out in the morning and you should get them within 2 business days.
Cheers.
I got a set of these a few weeks ago and havent had a problem at all...awesome result... also purchased some other things from Paul as well, Fast delivery! ill be keeping an eye on what you have in stock for sure!!!
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
