I would have LOVED to have been there, but didn't want to take a Skyline spot with the open wheeler. I couldn't take the GTR because there was an intermittent problem which Mark only resolved last weekend. But I watched the thread closely in case you called for extras and had my bags packed just in case, but it said it was full up :down:
The problem we were having with the GTR, simple as it was, it was hard to troubleshoot... ended up being a loose wire in the AFM, Mark cut the top off the AFM and found the loose connection inside, soldered it and it has been perfect ever since. In fact I spent all day on Wednesday in the GTR at Oran Park and got FTD :P:(:)
So there's a good message to all, look inside your AFM's before replacing them, it may be as simple as a spot of solder.
https://www.sau.com.au/forums/topic/30059-spotted/page/489/#findComment-3975117
Racing Drivers School, had to do a real grid start race to sit/pass my national licence, it was fuuuuuuuuuuuuunnnnnn.
Also... spotted this tonight, had no idea it was there http://www.irace.net.au/news/index.php?id=...913672475455476 now I really feel shpeshal :D
https://www.sau.com.au/forums/topic/30059-spotted/page/489/#findComment-3976950
Spotted a silver R33 at London Circuit - Northbourne intersection 12:20. they were in front of me.
And a Chameleon R33 [maybe, could have been a 32] coming out of Murrumbateman at 12:40 or there abouts, waved, don't know if they waved back.
https://www.sau.com.au/forums/topic/30059-spotted/page/489/#findComment-3981384
saw a black 33 when i was coming into canberra about 340 this afternoon near shell servo in EPIC.
i waived but i dont think i got a response.. i was in the white chaser
That was probably me. I was cutting around there about that time. Sorry totally didn't see you if it was me. I should introduce myself to the A.C.T crew sometime, but you know . . . effort.
https://www.sau.com.au/forums/topic/30059-spotted/page/489/#findComment-3988878
Hey baconer, are you YVB *** ? Dark blue LT 2000 that was turning right off Corranderk and into towards the Convention Centre?
haha yep that was me, guessing you were the silver 33 behind me. I see the silver 33 pretty much everyday when im crossing the road to work and it always makes me think about how much i regret selling my skyline
https://www.sau.com.au/forums/topic/30059-spotted/page/489/#findComment-3989445
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
