Mechanic found all rust in the chassis. all that money down the drain, if he doesn't refund then off to court we go.
dude that sucks so f**king bad..
hope i dont get a lemon when i buy my car
Gah, that sucks but it's not the end of the world. It is possible to repair rust in chassis rails. You will need to have it engineered, but it shouldn't be too much of a headf**k.
That is, of course, if you have no recourse against the person you bought it from. Was it private or thru a dealer? If private then you don't have a leg to stand on (unless he supplied the RWC - you will then have to go after who ever supplied the RWC), if thru a registered dealer then you should be able to get your cash back (even if outside the 30 day warranty period as it is a chronic problem that must have been affecting the car prior to you purchasing it).
GL with it!
GL with it!
Yeah I posted one page back but that was through our mechanic, took it to a proper body shop that's been in the business for over 30 years and he just looked at it and said its f**ked and you're a f**king idiot for buying it. It has rust in the front strut towers, all throughout the floor pan and in the boot as well, its too big of a job they have all agreed and a new chassis would be the only way to continue. It was bought privately from interstate (NSW) without a Roadworthy/Pink Slip, it has gotten pink slips in the past which is incredibly dodgy as without a doubt this hasn't just sprung up overnight. Currently it's not in our name we still have the transfer papers but we have paid the money to the previous owner. Waiting on a call from the previous owners father to find out if we're getting a refund or have to take them to court. I'm tipping the latter. If anyone want's to know the outcome of what happens here and if I keep looking for skylines after this situation just let me know and I'll keep you posted.
Cheers all,
Borci88.
Cheers all,
Borci88.
And if doubt get one of us to come check t out with you. Always good to go with someone who has one as they know what to look for. ( before you waste $400 for a vehicle check)
I've tried to get cars privately twice and nearly got burned both times, thankfully they only cost me a few hundred to get checked instead of the thousands the repairs would have cost. After the second I've vowed never again, it's LMCT or nothing.
Borci i rekn your best bet is to part the car out you'll pretty much recover your $7k.. going to court will take forever if you win..since from what i read you only have an old "dodgy" pink slip but i dont know how you can rely on that..? even though its a major problem over xxx period...
i mean if i sold my car with a 6 month old dodgy rwc..wouldnt mean much since its only valid for 30days regardless if its an ongoing issue your purchase wasnt based on that pink slip..
good luck anyway
Anyone go to the classic car show at flemington race course? Was huge.
Saw a merc gullwing, lotus esprit turbo, Porsche gt3rs and the first petrol car haha. He actually had it running and was driving around the car show. 2HP of fury
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
